Old 01-06-2020, 09:05 AM
andrewb70's Avatar
Sorry one more thing. I add an adaptor to the Dorman Master Cylinder to convert to -4 AN line. Make hooking up the clutch easier. You can just purchase a premade line to fit. I do add a dry break so if I do need to pull the transmission I don’t have to re bleed the system.
Earl's has a whole line of various fittings for OEM clutch connections, including the early and the later style dry breaks.
Andrew
Instagram @dr__efi
I offer remote Holley EFI tuning.
I deliver what EFI promises.
Please get in touch if I can be of service.
My YouTube Channel
Old 01-06-2020, 07:34 PM
CarlC CarlC is offline
Because the LT5 ECM is looking for a clutch switch and I’m adding Cruise control I added a clutch switch also while I was making stuff.
What type of user interface are you considering to actuate / control the CC?
http:www.vaporworx.com
Old 01-06-2020, 07:39 PM
I used to use the stock 4 th gen GM master cylinders then they got fairly expensive and they were plastic. I found this part on Summit Racing web site and it is aluminum.
Many folks modified the OEM 4th gen part with the "drill mod" in order to increase the flowrate through the MC. Are any other similar modifications needed for the Dorman part?
Old 01-07-2020, 05:00 AM
Stielow's Avatar
Stielow Stielow is offline
I’ve used the Dakota Digital Cruise control (The CAN) based one on 2 projects now and it is truly plug and play. You need a throttle by wire set up.
It works great and has an OE looking turn signal stalk.
Stielow Engineering
Old 01-07-2020, 05:50 AM
Stielow's Avatar
Carl off memory I think that restrictor was in the stock hydraulic line. Going to the Earls parts with -4 line opens the circuit up.
Some automotive development information. The restrictor is the stock line to help protect the driveline from snap clutch applications. With the restrictor you can’t run the engine up to redline and dump the clutch. The restrictor controls the apply rate of the clutch. If you get rid of it your system reacts faster. Downside your driveline loads go up and you break more parts.
Stielow Engineering
Old 01-07-2020, 07:19 AM
Thanks Mark.
BTW, the Wagner replacement MC is made by AP but I too like the aluminum Dorman part (on order....).
Old 01-09-2020, 05:21 PM
jmac jmac is offline
Awesome info, great detail.
1) What throw out bearing are you going to be using?
2) For the cruise control, is that only compatible with a factory ECM and not for something like a Dominator?
Old 01-09-2020, 07:05 PM
Stielow's Avatar
I’ll use a Centerforce throw out bearing and clutch. I think their throw out bearing is a Ford parts with a bit more stroke. But I could be wrong.
Not sure on the cruse control. Call Dakota Digital. They have a good tech line.
Stielow Engineering
Old 01-10-2020, 01:43 PM
Stielow's Avatar
I’m painting it White just because Charley hates it....
Stielow Engineering
clill's Avatar
clill clill is offline
I’ll kill u till your dead !!!!
