Old 09-15-2012, 07:57 AM
coolwelder62's Avatar
Rodger I will sign off on the design if you can't get SLO-Z/28 too do it.
Old 09-15-2012, 09:07 AM
ironworks's Avatar
For some reason I think I could buy your vote with lunch. Just sayin. If I came through tech with a BBQ pork sandwich we would suddenly be on the pole.
Old 09-15-2012, 10:28 AM
James OLC's Avatar
Originally Posted by Tom.A View Post
I really like this project. James please do start a thread on the '67 as many of us would like to see updates. I don't think anyone is tired of that car
OK... thread started... https://lateral-g.net/forums/showthread.php4?t=38370
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 10-27-2012, 09:32 AM
James OLC's Avatar
The roll cage is just about finished and ready for welding...
Roof bars are in and tied to the V bars in back
and the taco gussets are in where the rules require.
You can also see an "extra" bar in the footwell for some extra protection.
James
1969 Camaro - Dusty
Old 10-27-2012, 09:42 AM
bulldog19 bulldog19 is offline
Looking Good James!
Great work Ironworks. Top Notch as ususal.
John
68 Camaro RS Convertible Dual Quad 406 TKO600 Hotchkis TVSS SOLD
Old 10-27-2012, 12:14 PM
Sieg's Avatar
Sieg Sieg is offline
Good stuff!
What guage metal are the taco's?
Old 10-27-2012, 07:23 PM
Flash68's Avatar
Flash68 Flash68 is offline
Wow that might be the coolest cage I've seen in awhile.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 10-27-2012, 09:40 PM
CarlC CarlC is offline
Are you going to put some speakers in those doors? The cutouts are already there!
Nice work Roger! How about some "how-to" on taco fab?
http:www.vaporworx.com
Old 10-28-2012, 01:59 PM
James OLC's Avatar
NASA rules for the Tacos:
4.2 Gusset construction
Gussets are required to be made as follows:
1. U-shaped sheet metal (taco shell). Refer to figure 253-
34 below. Minimum thickness is .040” (1 mm). Minimum length along the unwelded side of the gusset is 3 times the tubing diameter.
2. Round tubing. Minimum length of the longest dimensions is 3 times the tubing diameter. Minimum tubing diameter is 1” with minimum wall thickness of . 083”. Maximum diameter and wall thickness is per the materials in table of section 6.6.
3. One or 2 triangular plate steel gussets with combined thickness equal to the tubing which is being gusseted. Minimum length along the unwelded side of the triangular gusset is 3 times the tubing diameter.
Any plate or u-shaped gusset that is welded into a joint location where it can block the view of the welds between the tubes being reinforced must have the corner cut back to enable visual inspection of the tube joint. This is illustrated in figure 253-34 and typically looks like a bite out of the corner of the gusset.
Definitely Carl! I was thinking that a full sound system with three subs, four amps and twelve speakers should do it! Or not... If anything I thing that a few hours with a hole saw will get the rest of the inner door in good shape!
James
1969 Camaro - Dusty
Old 10-28-2012, 02:28 PM
Sieg's Avatar
Thanks for the education James.
