Old 07-02-2011, 10:36 AM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
Thanks all!
You have to pull the motor to change plugs??
Not a bad days work there!
There is actually a lot of room there. The bottoms of the inner fenders are not attached to anything in these pics and are way closer to the motor than they will be when completed.
Originally Posted by DJW32 View Post
Looks like those vents are functional...damn... very nice work.
The vents are functional. They house K&N air filters and there is then duct work that runs under the inner fenders to the intake.
www.roadstershop.com
Old 07-02-2011, 10:39 AM
Supporting Vendor
RoadsterShop.com
Inner fenders further along and engine detail starting to take shape:
Old 07-02-2011, 01:23 PM
strtcar strtcar is offline
Looks great.
Question, do you guys put anything in the metal/body while working on it so it doesn't flash rust? About to get my 70 Chevelle blasted and then start body work/panel replacement. Was thinking about leaving it bare until metalwork is done then epoxy prime.
Old 07-02-2011, 02:00 PM
mexMan's Avatar
mexMan mexMan is offline
OH MY GOD, the build is impecable, plain awesome, every detail on it, so clean, so cool.
''Every car has a great quality, is not the hands that build it, is the dedication behind it.''
Old 07-02-2011, 02:19 PM
Sandbagger's Avatar
Sandbagger Sandbagger is offline
How did you guys form the upper aprons ? By the vent ? How many peices ? Pullmax,hammerform ?
I cant tell from the pics .
Old 07-02-2011, 02:55 PM
Looking great. You guys are hauling arse on this fab work.
John
'71 Nova (Build thread)
FFR Roadster
Old 07-03-2011, 02:27 PM
Supporting Vendor
RoadsterShop.com
Originally Posted by strtcar View Post
Looks great.
We leave all cars in bare metal through out the build process. While under construction we generally use just a scuff pad to keep the metal clean. When the car is ready for body work we spend a lot of time metal prepping the entire care to make sure that all rust and traces of it are gone.
Old 07-03-2011, 02:40 PM
Supporting Vendor
RoadsterShop.com
Continuing fab work on the engine detail:
Beginning to fab the recessed center portion.
Pocket detail added to front.
Start of the upper radiator close out panel. Also fabbed a template for the grille.
Old 07-03-2011, 02:48 PM
What are you doing for the stereo, looks like an opening left for a double din type radio. GM Factory unit perhaps?
1/12th scale 1969 Sunset Orange Metallic Camaro Pro Touring Style>>
Progress Thread
Artwork Page
Old 07-03-2011, 03:38 PM
Supporting Vendor
RoadsterShop.com
Upper radiator close out panel completed and transitioned into the inner fenders. We went back and put a seam in the the inner fender before it meets the radiator close out panel to add more detail to it. Also have the pocket installed for the BMW hood latch.
Start of the trim piece around where the engine metal work meets the close out panel.
We then went back and put another seam in the forward panels coming off the intake.
Everything metal finished.
