Old 11-11-2014, 06:43 AM
mikels mikels is offline
Originally Posted by PTAddict View Post
I don't have the dimensions. But Stielow also used this fan on Red Devil and Mayhem, which both had more conventional radiator packaging ...
Shroud is 609 mm wide x 585 mm tall ( 24x23 inches)
Fan itself is not much smaller.....
Old 12-22-2014, 05:08 PM
samckitt's Avatar
samckitt samckitt is offline
So i gave these instructions to a friend to wire up the Vette PWM module. I told him to use pin J3-64 as the signal wire. He says it doesnt work and used J3-49 instead & it worked. What's up? Which pin have you guys used?
Thakns
Scot
86 Monte SS
LS2/T56 Magnum
Old 12-23-2014, 05:08 PM
Thakns
J3-49 is correct for E67 PWM fan output control. (assuming you have also changed calibrations for PWM fan control)
Dave
Old 12-24-2014, 08:34 PM
samckitt's Avatar
Thanks Dave.
Plugged it all in tonight to test, and after a few small bugs, it works! Its cool. No spike in amp draw, fan starts up slow, runs at a lower speed until you t gets hotter then runs faster. Cool.
I'm still looking for the real Bette connector and f anyone finds a source. I just used individual spade connectors.
Scot
86 Monte SS
LS2/T56 Magnum
Old 12-26-2014, 08:46 PM
andrewb70's Avatar
Scot,
What fans are you using?
Also, does anyone have the dimensions of the C6 fan pn 15819952 ?
Andrew
Old 12-27-2014, 06:22 AM
samckitt's Avatar
Before I started the LS swap I had an LT1 in the car and was using mid 90s impala SS fans. Still using them. I'm using one corvette module to power both fans.
Scot
86 Monte SS
LS2/T56 Magnum
Old 12-27-2014, 11:31 AM
andrewb70's Avatar
Thank you everyone for posting the relevant information. Looks like I can use a C6 Corvette fan (it already comes with the controller plug), in my Cougar build. The plan is to use the Corvette controller module with the Holley Dominator ECU.
Anyone see any reason why this wouldn't work?
Andrew
Old 12-27-2014, 11:59 AM
68Cuda 68Cuda is offline
Anyone know if the PWM output #1 (pin A19) on the XFI 2.0 can be used for fan PWM controller input?
Michael
Plano, TX
1968 Barracuda Notchback
Body & Paint:
http://www.forabodiesonly.com/mopar/...dy-2014.10252/
Engine:
http://www.forabodiesonly.com/mopar/...ictures.10230/
Old 12-29-2014, 08:59 AM
samckitt's Avatar
I want to add a Maxi fuse to the existing GMPP fuse box for the fans. I need this terminal for 10 or 12 gauge wire:
Anyone know where to get some?
Scot
86 Monte SS
LS2/T56 Magnum
Old 12-30-2014, 03:38 PM
andrewb70's Avatar
For the sake of keeping this thread updated, the above terminal is found here:
http://www.ese4you.com/Delphi.pdf
Page 31.
Andrew
