Originally Posted by WSSix
Looking good. Are you sure those gussets will be plenty?
LOL. No. But I think they will. I'm confident in the UCA mount and gusset as its similar to DSE's which has gone through finite element analysis but the upper coilover mount is based on my own madness. I'll keep a close eye on them.
I should add the coilover gusset goes all the way down to the bottom of the UCA plate beneath the surface of the subframe. I did this to resist stretching or tearing with vertical force and should prevent buckling sideways. I think the weakest point is the ears bending sideways in the top area but I'm confident the bolt and press fit spacers under tension will prevent that. The packaging requirements made this tough as the UCA shaft is on the motor side and I need the clearance on the ears for the coilovers to fit. I formed some more pieces out of 1/8" to box in the top too if I need them. The UCA mounting plate is 1/4". The UCA gusset and coilover mount ears are 3/16" and the reinforcement I added is 1/8".
