Old 09-29-2015, 06:57 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Default Available Now
This style is NO LONGER stocked. Available by special order only.
Price now includes hard black anodize on the billet hub spacers.
For "Basic Kits" sold in the month of October I will include the pictured bearing unit mounting hardware.
Thanks for looking!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 11-30-2015, 05:54 PM
ma73z's Avatar
ma73z ma73z is offline
Default Availability
Any basic kits available?
Matt (amateur jack stand class)
73 Camaro in slooow process
69 Firebird LS1 4l60E
70 Chevelle 402bb tko600
Old 11-30-2015, 07:15 PM
Yes, simply PM me your email, full name, shipping address, phone number, and I will send you a PayPal request. Once payment is received your kit will be in the mail the following day!
Thank you for your interest.
Jay
Old 12-05-2015, 08:52 AM
Mickav6 Mickav6 is offline
i assume it work with the 10 bolt?
Old 12-05-2015, 04:09 PM
Yes, this set-up can be installed onto your 10 bolt, the set-up does not discriminate
You will not have the option of Gun-drilled axles due to your carrier spline/axle diameter size, but no big deal there. Let me know if you have any other questions.
Thanks,
Jay
Old 01-04-2016, 08:50 AM
ma73z's Avatar
Jay
PM sent, thanks.
Old 02-01-2016, 03:11 PM
mdes0 mdes0 is offline
Default mailbox is full
Hey Jay. your mailbox is full so can't send you a PM. Had a question about the weld on ends before I put in an order.
Thanks,
Matt
Old 02-01-2016, 06:04 PM
Thanks,
Matt
Hi Matt,
Cleared space in my mailbox, I sent you a PM as well.
Thanks, Jay
Old 02-01-2016, 06:42 PM
Default New Style...... Weld-On
The description/picture below reflects the all new Weld-On kit.
The original style in my previous posts will still be available, but will be available by special order only, and will be price quoted at time of order.
C-Series: Weld-On “Deluxe Kit”
Advantages:
• Weld-On To Your New or Existing Housing
• Front Or Rear Caliper / E-Brake Cable Mounting Positions
• Utilizes The Robust, Zero Maintenance C6 ZR1 / C7 ZO6 Corvette Hub Assembly
• Utilizes ALL OEM Brake Kits Designed For C5/6 Corvettes
• Utilizes ALL aftermarket Brake Kits Designed For C5/6 Corvettes
• Utilizes Your Existing BAER or WILWOOD Caliper & Rotor (some restrictions apply)
• Utilizes C5/6 Corvette OEM E-Brake Assembly
• ABS / Traction Control Compatible
• Super Compact Design Compared to Traditional Full Floaters
• Advantages Of A Traditional Full Floater Without The Maintenance
• Replacement Parts Available At Local GM Dealer Or Local Parts House
• Wheel & Tire remains intact should an axle ever snap
• Eliminates Piston Knockback!
Deluxe Kit Includes:
• (2) Billet Steel, C-Series, Hybrid Floater Ends
• (2) C5/6 Billet Aluminum Caliper Brackets
• (2) C7 Corvette, SKF 33 Spline Hub Assemblies
• (2) C6 Corvette Complete E-brake Assemblies
• (2) C6 Corvette Parking/E-brake Cable Brackets
• (1) Install Kit - includes all hardware & axle seals
________________________________________
STARTING AT - $1,598.00
Note: The success/longevity of this system is based on the correct fixture tools & the use of.
