Old 02-01-2017, 09:26 PM
Sonar Chief's Avatar
Cool Good garage day!
Been a long day ... I hung the Ride tech cradle that I sprayed yesterday and finished the Millerbuilt axle installation and got the rear end hung today! Takes time when everything is painted and you are by yourself ...
Well take a look ...
I'll finish hanging the shocks and get the brakes mounted and test fit the front wheel ... hopefully the bs will be the same for the rear, we'll see!
Thanks for looking ...
Old 02-01-2017, 10:29 PM
Build-It-Break-it's Avatar
Amazing work. It's funny cuz I've watched your build for awhile now and I'm excited for you. I'm sure most people on here are to. Keep at it, your not far away!!
Ahmad B
Old 02-02-2017, 03:41 AM
paulk68 paulk68 is offline
completely agree such an awesome build to follow!! I can not wait to see what he does with the wrap!!
Old 02-02-2017, 10:03 AM
Panteracer's Avatar
Panteracer Panteracer is offline
Default My 1967
Looks very clean... thank you for posting up
I am thinking of doing the Ridetech system vs a
torque arm and this helps me see the clearances etc
I have my 3" exhaust running under my rear end and
with this system I would not have to modify anything
Keep at it
You still in California?? having a superbowl party at
my shop in Campbell, Ca.. Pantera guys but still car guys
you and any lateral g guys/gals are welcome to come on down
442 industrial, Campbell, Ca noon till ???
Bob
Old 02-02-2017, 10:15 AM
Zoomin Zoomin is offline
I see you are running a Ford rear along with the RT 4 link set up. Just thought I'd pass along some info about a minor issue I ran into - the lower brackets on my rear end were off 1/2 outboard on each side. Sight along the lower trailing arm and see if it looks like it's running parallel.
This difference caused the lower coil-over eye mount to come in contact with the wheel rim.
You probably don't have that issue, but it may come in handy for some to check before getting too far along.
1964 Lemans
1966 Skylark
1969 Camaro
Old 02-02-2017, 01:03 PM
It looks good in there.
Old 02-02-2017, 02:49 PM
preston preston is offline
That may be the correct location, its not uncommon to have the rear end pickup points slightly wider than the frame pickups on the lower arms.
Tell me about it, I've spent the last 20 years building my car all by myself in a carport no less ! I'm always fascinated by those tv shows where multiple people are working on a car, much less helping each other.
Swinging in the engine, mounting doors, taking hoods on and off, not easy as a one man show. My wife/kids start complaining after even just 30 seconds of oscillating the steering wheel or pumping the brake pedal for me.
Old 02-02-2017, 03:28 PM
Red face No-go!
Thanks, getting closer!
Thanks, never done a wrap before, steep learning curve!
Keep at it
Bob
I'm still here til end of March, thanks for the invite just not into the Super Bowl!
I put the brackets on so all should be square, hopefully!
Thanks Wayne, think it has a nice contrast under there!
Yeah it's slower when everything is painted One man show here too!
Bad news first ... won't be able to use the same wheel size in the rear, good news is I know what will work!!!
First, there is a difference of 3/16" stickout in width between passenger side and driver's side, what ?? ... measured everything again and all is square with the mounts and rear seems the passenger side quarter panel is 3/16" narrower than the driver's side (based on rear frame rails).... go figure.
Update ... it's not as bad as I stated, it's only 3mm or 3/32" difference between sides, still gonna need more bs than these fronts!
Second, I have plenty of clearance on the inside, 2" to top of tub and 1" to lower shock mount, so I just ordered a larger bs for the rear rims, no biggy! I would rather have plenty of clearance to the wheel lip than just enough!
For those that need visuals ...
Passenger side way too close to lip!
Plenty of clearance here ... so more BS!
1/2" to rubber!
Almost 3/4" to rubber!
Those wheels just look cool!
I put the driver's side through compression and it would clear w a lip trim but the passenger side was a no go ... so I'll trim the lip some and have a different bs rims on the back, no biggy! Glad I did it this way instead of ASSUMING !
Old 02-02-2017, 03:38 PM
It looks good in there. It fits nice and tight to the frame rails.
Old 02-02-2017, 05:01 PM
Thanks Wayne, I have plenty of room to move inboard!
My OCD got the better of me and I remeasured both sides it's only 3mm or 3/32" difference!
Michael
