Closed Thread
Old 03-19-2010, 08:41 PM
monza's Avatar
monza monza is offline
YA
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
62 Corvair Greenbrier
http://www.sourceboards.com/
  #1332
Old 03-19-2010, 09:49 PM
Most of you know I've spent many many late nights and afternoons away from work trying to get my car back on the road. It's been almost 4 months since I pulled the old engine out! While swapping engine sounds simple, I can't make anything simple. I can't leave anything alone either. I'm to the point now where I'm doing over before it ever leaves the garage. If I don't like it, I start over. Anyway, here's a list of the changes I made.
  • Aluminum block and all that entailed
    Oil cooler and all the plumbing
    Cooling system to dual pass with internal heat exchanger
    A/C
    Heat
    Custom condensor brackets
    Made all my own AC and heater hoses
    Re routing two wiring harnesses underneath
    Adding weatherpak connectors all over the place
    Rear sway bar with custom designed brackets and hardware
    Custom coil bracket
    Brushed valve covers
    Custom water recirc tank bracket
    Brushed all A/C/Heat fitting
    Added dual breather tanks and brushed them
    Different valve covers
    Re routed fuel lines to come in from the rear and take all 90's out at regulator
    Jet extensions
    Recoated headers
    Changed gates clamps
    Brushed the air cleaner lid(Took two ) lol
    And about 50 more I can't remember
I fired her up around 4 or so. I had the timing light ready but noticed the crank pulley was wobbling badly. I couldn't of left it loose. So off comes the belt and it turns out that a couple bolts that hold the ATI balancer together were sticking out maybe .015 of an inch. I had some brake caliper shims handy and put them between the pulley and balancer and it's perfect. Once I had that fixed I cranked the idle up to about 2k and set the timing consservative. Then the cooling system belched and I topped it off. Dialed the idle down and had a 3"x3" oil puddle after about 15-20 minutes. It's leaking between my one way valve and 45. I loosened and retightened and it still leaks. Brand new earls stuff. I'll get it figured out. Other than that it sounds great. The oil coolant temp was about 185 hot and the oil temp was 190. The heat exchanger is working perfectly.
While the engine compartment is brand new I took the chance to shoot some photos. I'll post the old engine compartment last.
  #1333
Old 03-19-2010, 09:50 PM
  #1334
Old 03-19-2010, 09:51 PM
  #1335
Old 03-19-2010, 09:52 PM
  #1336
Old 03-19-2010, 10:00 PM
70rs's Avatar
70rs 70rs is offline
Todd,
Remember the PM I sent the other day? So true! This is just awesome! Really nice work Todd. I really like the twin breather tanks and lines, nice touch.
You have outdone yourself with this entire car.
I read your reply on the tow hooks. As tie downs for the rear they should be way more than enough. And they look great too.
Eric
  #1337
Old 03-19-2010, 10:08 PM
DFRESH's Avatar
DFRESH DFRESH is offline
Todd--it is beautiful man---that's the Schnizel for sure---love the breather lines---perfect blend of brushed aluminum and black hose/fittings. You did a great job. Can't wait to see it in 2 weeks bro. Let us know what you find on the oil leak.
Doug
  #1338
Old 03-19-2010, 10:21 PM
skatinjay27's Avatar
sweet! maybe ill come over tomorrow to help ya get the hood on...
AJ
  #1339
Old 03-19-2010, 10:25 PM
^^^^^^^ What he said!
Looks really really nice Todd... Good job!
If you can't stop the leak on the fitting - Doug and I can pick up a Flare Saver for you at Marks (Bent Fab) on Thursday before you get over to El Toro... just let us know what size it is.
  #1340
Old 03-19-2010, 10:28 PM
89 RS's Avatar
89 RS 89 RS is offline
Very nice man, like the mix of black and brushed aluminum. Sucks about the oil leak, but I'm sure you'll figure it out. Keep us posted.
Corey
1989 Camaro RS
Closed Thread
