View Poll Results: What engine will you be using?
SBC w/ EFI 42 6.99%
SBC w/carb 98 16.31%
BBC w/ EFI 41 6.82%
BBC w/ carb 50 8.32%
LSx 205 34.11%
LSx w/ forced induction 80 13.31%
Other 70 11.65%
SBC w/ EFI & Forced Induction 15 2.50%
Voters: 601. You may not vote on this poll
Old 05-03-2012, 05:40 PM
Flash68's Avatar
Flash68 Flash68 is offline
Matt, I wish my intake looked like that. Killer!
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 05-03-2012, 06:19 PM
badmatt's Avatar
badmatt badmatt is offline
Originally Posted by Ron in SoCal View Post
^ That is just too cool Matt! Are you going to detune it for some street duty or just leave it all bad mamma jamma?
new cam with a bit more lift and duration (pump gas and to pull about 500 rpm out should make roughly the same power..) but basically staying the same and a custom carb by Brian Wheatley
damn why did i build an S10.. and not a 71 Camaro..
Can you say plenum volume?
Old 05-03-2012, 06:44 PM
Flash68's Avatar
Can you say power range from 7000-9500?
Those spider intakes always look the best.
2014 4 tap Keezer
Old 05-03-2012, 06:54 PM
badmatt's Avatar
Hey! I could cruise around the city with out needing to get out of first.. like I said rolling 80mph burn outs...
Old 05-05-2012, 03:08 PM
FETorino's Avatar
FETorino FETorino is offline
Originally Posted by 56pickup View Post
A FORD
Nuff said.
I miss
Mopars, Pontiacs, Olds, Buicks, AMCs
Remember when they were options for a street car
Rob in SoCal
Old 05-23-2012, 08:46 PM
crobin4's Avatar
crobin4 crobin4 is offline
Mine qualifies as "Other"
427 Small Block Oldsmobile
Old 05-24-2012, 12:50 PM
Firebirdsteve's Avatar
Firebirdsteve Firebirdsteve is offline
Recently took delivery of my GMPP LS3 525...
Well....Speed Tech did actually
1981 Pontiac Firebird
Build by Speedtech Performance
http://www.speedtechperformance.com/...rod/prd287.htm
Old 05-24-2012, 08:44 PM
crobin4's Avatar
Originally Posted by FETorino View Post
Nuff said.
I miss
Digging the engine for your Torino.
Christopher
"I would rather die of passion, than to die of boredom"
-Van Gogh
Old 10-01-2012, 05:32 AM
Rebeca_Lynn Rebeca_Lynn is offline
Default Ford Modular Motors
MMR built 5.5L 4V Aluminum block, bored and sleeved to 5.8L
Billet aluminum water pump blockoff plater for remote mount and MMR head cooling kit.
Custom Billet aluminum drive system for A/C, Alt and Avivid Drysump pump
Avivid Billet Aluminum 4 stage drysump pan and system
MMR GT500 3R heads, oversized valves, ported and polished, custom ground cams for SC
Kenne Bell 4.2L Liquid cooled supercharger with custom rear mounted TB plenum.
I am using the same engine package in both GT40 MKII replica build and my SLC builds.
Old 10-01-2012, 07:51 AM
Jakespeeds Jakespeeds is offline
Lexus 1UZFE with a Eaton M112 supercharger in a 73 Nova SS.
Jake <--Flame suit on!
