Old 10-21-2012, 04:11 PM
wedged wedged is offline
a few weeks ago I put the bed in place and tack welded it to keep it from moving. Now I can make the brackets for it. I think I've got the cab floor figured out too, now I need a sheet of diamond plate steel.
Didn't get much done this year, but I'm not in a rush.
Old 03-17-2013, 01:47 PM
yesterday I finally got some more done on the headers .
I still need to trim the collector length and add flanges . I'll likely run them awhile and then have them coated.
Here's the driver's side. Originally I thought I might have to get creative with the steering column and shaft, but it looks like it will be easier than I anticipated.
Today I made a couple of bed mounts. The through bolt is sleeved so when it's tightened it will not crush the frame. I need to make 4 more similar to them and then the rear ones will be quite a bit different. I'll finish welding them with the bed removed from the frame.
Old 03-17-2013, 10:28 PM
Nice to see your still at it.
Old 08-28-2013, 04:16 PM
R.A.D's Avatar
R.A.D R.A.D is offline
any updates?
LIKE THE MAN SAID "EYE BALL IT"
http://fordodgetrucksonly.forumotion.com/
RIDESBYDESIGN.COM
Old 08-30-2013, 06:24 PM
No, but maybe over the next few weekends
Old 01-02-2014, 04:36 PM
rear bed mount. need to add the through bolt of course.
Old 01-04-2014, 03:16 PM
finished the bed mounts and welding in the reinforcement tubes in the frame.
Old 01-04-2014, 03:27 PM
revmopar revmopar is offline
good to see you still plugging away at it. I bought a couple of old Dodge trucks and have started on the 38 I bought, it's going to be more street rod than pro touring but it should be fun.
Eugene Braswell
Old 02-08-2014, 05:02 AM
had a piece of 14 gauge sheared to fit a portion of the floor. I need to add a hump to clear the trans.
Old 02-09-2014, 01:21 PM
trimmed some more of the old floor away and made a small notch just to get the floor to lay flat. test fitted a seat too.
