Old 01-10-2010, 10:14 PM
David Pozzi's Avatar
Steve,
That radiator setup looks great as is, I like that better than the DSE closeout.
A separate cooler is good. I like the engine combo, should make tons of torque and weigh nearly the same as before.
David
http://www.PozziRacing.com
Old 01-10-2010, 10:16 PM
nvr2fst nvr2fst is offline
Originally Posted by Steve1968LS2 View Post
Hmmm.. what's that writing on the inner fender well???
Looks like my initial thought I posted maybe wrong.
Steve,
Your reincarnation thread has been very informative. Your product installations, reasoning for why the change is made and what weighed out in the product selection has been doc. perfectly. But..I wouldn't except anything less coming from you. Great work so far and try not to scratch it during reassembly!
Old 01-11-2010, 07:38 AM
Steve1968LS2's Avatar
Originally Posted by David Pozzi View Post
Steve,
David
Yea, I think the MID sleeves add about 6 pounds. So, almost the same weight.
I like it better as well from a "looks fabbed" standpoint. But I'm use to the DSE part. Also, this one is trickier to remove if I need access to the oil cooler system or other part. This is because some screws go in from the bottom. With my mesh that would be a PITA.
Old 01-11-2010, 08:02 AM
Bow Tie 67's Avatar
Bow Tie 67 Bow Tie 67 is offline
Upgrades look nice, I agree with David on the close-outs. Maybe you can incorporate some type of Dzus fastener, after all Penny is more so on the race side of the line than street. ( that is a good thing )
Matt
Project: " Chain Reaction "
A.K.A. " BIG " by wife, biatch in garage.
1969 RS Camaro, L92 T56, Chassisworks sub, Quadra-Link, Bear, Ford 9".
Old 01-11-2010, 10:35 AM
buickfunnycar.com's Avatar
Looks real slick Steve...
www.buickfunnycar.com
Old 01-11-2010, 06:15 PM
customcam's Avatar
customcam customcam is offline
Leave is it as it is! lol yeah rite
Steve a bit modest on the Hp prediction of that 440?
Old 01-15-2010, 09:09 PM
Yea, so we said screw it.. let's see if we can make it a 454. lol
New plan:
Tomorrow the 402 comes out so we can re-undercoat the car.
Here's what we have so far:
Sleeved LS2 block (Darton MID)
Mast Motorsport 12-degree LS3 style heads
4.185 bore
4.125 stroke - Lunati Pro Series crank
6.125 K1 lightweight (614g) H-beam rods
Wiseco Pistons yielding about 11.5:1 compression
Comp cam on a 114 LSA.. should idle pretty smooth.
FAST 102mm LSXr intake
Ported TBW throttle body
Canton oiling system
ARP everything
That would make this a 454 aluminum small-block LS engine. Conservative estimates are 670hp and over 600 lb-ft of torque.
Weight gain, due to the sleeves, should be around 6-lbs
Just need to do a few mods to the Canton oil pan. Still doing the math on it, but it should work just fine.
Old 01-15-2010, 09:14 PM
89 RS's Avatar
89 RS 89 RS is offline
Sounds like that's going to be one nice engine. Very nice Steve. Are you doing an article on it too?
Corey
1989 Camaro RS
Old 01-15-2010, 09:29 PM
454, is that a big block? You're like me, pushing the limit every chance you get. I like it....
Old 01-15-2010, 11:04 PM
Yep.. Looks like it will be in CP and most likely Engine Masters since it's a bit unique.
More like a big small-block I guess.. It is sorta crazy what you can do these days.
