Old 04-17-2011, 02:49 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
AJ,
I got a good chuckle out of your "half welded ground down and sanded"..... You and I must be a lot alike. I can't stand just welding for 2 or 3 hours... I have to stop and partly finish.... then make a patch... then weld some...
lol i could only sit in there welding for so long before i got too bored to do anymore. the other side is welded now but i haven't ground it down yet. figured i do it when i grind the 3rd link cover.
Originally Posted by speedshftr View Post
you are very very talented.i just read the whole thread.my hats off to you.
thank you.
Old 04-21-2011, 09:37 PM
CamaroAJ's Avatar
been pretty busy so i haven't gotten a lot of time to work on the car. i did get the other muffler done so that makes 2.
and the fuel cell done.
mocked in the cage to check fitment and measure for the fill panel i needed to make.
needed to cut the stock fill hump shorter and fill it back in.
then using 3M 8115 panel bond adhesive i mounted the cage to the car. it holds the cage in as well as doubling as a seam sealer. its also welded in a few places and will also be tied to the frame and cage.
after it dried i put the cell in.
at the lowest point its 8". thats more than i had in my '67 and there has never been a clearance issue with that car.
Old 04-22-2011, 06:27 AM
coolwelder62's Avatar
Wow!! That look's great.Will the tank have a EFI pump in the tank or outside. Scott M.
Old 04-22-2011, 02:35 PM
CamaroAJ's Avatar
pump inside, i'm planning on 4-6 pick ups so i don't have to put in a trap. its the same pump i had in my other car. its been in that car since '06 with zero issues so i feel really good about using it again.
http://www.jegs.com/p/Aeromotive/Aer...50904/10002/-1
Old 04-26-2011, 08:44 PM
CamaroAJ's Avatar
been busy and haven't had a lot of time to work on the car. i did finish the the 3rd link cover today though.
lots of welding and grinding all day. it sucked but now i have to grind the bottom which will suck even more. i might just wait on that until i get it on a rotisserie.
greg, i finished grinding and smoothing the other side.
Old 04-27-2011, 06:27 AM
Lookin great as alway's.Really going to have a great ride when your finished.
Old 04-27-2011, 05:06 PM
johnnymac46's Avatar
johnnymac46 johnnymac46 is offline
I've been following your build for a while now. This is going to be one bad car, it looks awesome.
Old 04-27-2011, 07:26 PM
CamaroAJ's Avatar
thanks guys, looking forward to driving it more than anything.
Old 04-27-2011, 07:35 PM
bonecrrusher's Avatar
bonecrrusher bonecrrusher is offline
Where are the mufflers going to sit?
2005 LeMans Blue Corvette w/ T56 & Z51 & C6Z06 Brakes, Build Thread: https://lateral-g.net/forums/showthread.php4?t=27408
2005 GMC Sierra 2500HD - LLY - Allison
2014 Chevy SS - LS3 / 4 Doors
Old 04-27-2011, 08:05 PM
CamaroAJ's Avatar
not sure yet. i want to try and put them on either side of the fuel cell. if not then they do fit in the stock location (already checked fitment)
