This isn't a big update but one I'm a bit proud of.
The Corvette front tie rod ends are difficult to source, I wanted to go with an adjustable bump steer rod end and have to connect to the flaming river rack. A lot of people suggested reeming the bore out with a 5/8 bit and running a bolt through but I decided to go the hard way.
This is a GM tie rod end, one of the adjustable bump steer ends with the incorrect taper.
I made a sample for test fitment
These are the two new rod ends
And on the car but needs to be tightened in and adjusted.
This was fun but if I had to charge an hourly rate for the time they were friggin expensive!
