Old 05-01-2013, 08:21 AM
Sorry I missed meeting you Dale!
I'll see ya at a Beaches Wednesday afternoon....
Old 05-01-2013, 10:38 AM
96z28ss's Avatar
96z28ss 96z28ss is offline
What you bringing?
Sieg are you coming to beaches also? Mini lat-g get together?
1969 Camaro LS2/T56 D1SC
www.automotivedesigneng.com
Old 05-01-2013, 10:46 AM
Sieg's Avatar
Sieg Sieg is offline
Originally Posted by 96z28ss View Post
What you bringing?
I know nothing of their little date
Old 05-01-2013, 01:04 PM
What you bringing?
I'd bring "da rig" with everything!!! LOL
If you've never been to a Wednesday afternoon Beaches show in Portland -- ya ain't lived yet! They don't start up for awhile yet -- but often have 1500 cars -- and 600 murdercycles.... they start at 3:30is and runs til about 7:30 or 8:00... drags -- music -- food -- booze -- cars... what's not to like??
You'd also get to watch Old Gold hammer the track there like it's made of glue...
Old 05-01-2013, 01:31 PM
96z28ss's Avatar
We should all meet up sometime in June when they start. Not the first week though cause it's the Rose Festival, and that's a guarantee that it will rain.
Old 05-01-2013, 02:27 PM
Sieg's Avatar
Sounds like a plan!
Old 05-01-2013, 10:55 PM
DaleTx's Avatar
DaleTx DaleTx is offline
Originally Posted by Ron in SoCal View Post
You KTM vinyl top guys gotta stick together
Dale part one above was great. Looking forward to part two!
I'm not seeing of lot of builds on this site going with the vinyl top look, Lol. The cosmetics on my car are pretty much all original so far.
I took a bunch of pictures today of the plumbing underneath the car to post. Are you putting your tank in the engine compartment or in the trunk?
Now that garage looks Proper! Good deal all the way around Dale. Look forward to the next time.
Ron must have confused KTM with KY
Thanks Scott... It's good to get to know few guys on here
Thanks Greg... a Beaches Lat-g get together sounds good!
Sounds good, maybe we can get Tim out there to.
"If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
Old 05-01-2013, 11:29 PM
DaleTx's Avatar
Default dry sump plumbing from engine to tank in trunk
Here is a shot of the plumbing for the three scavenge lines on the oil pan. My engine was run on the engine dyno with the dry sump pump and measured 10 inch HG vacuum. The valve covers are completely sealed with no vents. The only vent is a 4AN line plumbed into the valley cover that goes to a remote breather.
Here are some shots showing how I routed the plumbing underneath.
You can see the plumbing in the left side of pictures tucked up next to the frame rail and sub frame connectors.
I also up-sized my exhaust to 3" all the way back for the new engine. I bought some mandrel bent tubes and had some tubes custom made...
then fit and welded the tubes. This was my first time to do my own exhaust.
These shots are from the back of the car looking forward... the oil lines go up into the trunk and attach to the oil tank.
I ran the oil lines up above the new cross member that came with the T56 Magnum... this worked out good to keep the lines away from the exhaust.
Mario Andretti
Old 05-02-2013, 12:07 AM
DaleTx's Avatar
Default dry sump pump system install
When I modified the tunnel for the T56 magnum trans I also cut a notch in the floor on the passenger side for the dry sump oil lines.
This allowed me to tuck the oil lines up above the exhaust to prevent heat damage. I used 1-1/2" square tubing... cut it to fit... and then welded all around.
This shows the clearance of the oil lines to the headers.
The oil lines are sitting on top of the sub frame rail.
Here is a shot of the oil lines going into the notch I cut in the floor. This worked out well and the lines have plenty of clearance from the exhaust.
The lines continue on and go up above the T56 trans cross member and then alongside the frame and sub frame connectors back to the tank in the trunk.
The oil lines are up above the frame rails the whole length of the run.
The oil lines do not go below the frame rails at any point.
Mario Andretti
Old 05-02-2013, 04:35 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Very nice work on this one Dale,some great ideas
