Old 09-06-2015, 08:21 PM
zj510's Avatar
zj510 zj510 is offline
Default 70 Camaro Pro-Touring Yet Another One
Yet another 70 Camaro build. I am new to lateral g and decided I would share my build hoping that some might share some insight on the build. I am building the car to be a good driver with intentions of autocrossing it every once in awhile. I purchased the car a little over a year ago so quite a bit has been done already. The car will be getting a ls motor with a 6 speed, Detroit speed Quadralink, 12 bolt, global west control arms and custom works performance front coil over conversion and many other of the usual parts.
Old 09-06-2015, 09:06 PM
zj510's Avatar
Talking
Here is the car when I got it home. Has alot of issues it had been swung into a pole on the drivers side quarter they pulled out the quarter but the rear structure was left and both quarters are rusted out and also the trunk so it will be getting new gm rear sheet metal
Old 09-07-2015, 07:12 AM
fleet's Avatar
fleet fleet is offline
Welcome.
Looking forward to seeing this one come together.
#RSnoseFTW!
Old 09-07-2015, 08:07 AM
Welcome to Lat-g, and we love new projects. I'll be watching for your updates.
Old 09-07-2015, 10:21 AM
zj510's Avatar
Here it is on its way to the body shop the whole back end is getting cut off and new nos gm sheet metal is going on
Old 09-07-2015, 10:26 AM
zj510's Avatar
Default Its cut
Here are some pictures of it bare and with sheet metal going back on I already had cut for the mini tubs at this point once it got home I finished them up and its time for the Quadralink and mocking up the front suspension and motor and transmission.
Old 09-13-2015, 11:14 PM
syborg tt's Avatar
Wow your really cranking on this car and it looks really nice.
Marty-MJ
www.garagescene.net
marty-mj
Old 09-14-2015, 12:37 AM
Tokyo_Torquer Tokyo_Torquer is offline
Interesting build.. what size tires?
1973 RS Z28, 401ci Dart Little M with AFR 227 comp porting heads, Callies Magnum crank, Lunati Pro Mod Rods, JE blower pistons @ 7.8:1, Littlefield 6-71 with 14 lbs boost, Reed solid FT cam with 240/250 duration @ .050", .523/.542" lift and a 112 LSA, T&D 1.6 shaft rockers, Lemons 1.875-2.0" step headers
Old 09-14-2015, 06:25 AM
cpd004's Avatar
cpd004 cpd004 is offline
Coming together nicely!
1971 Firebird
2017 SS
Old 09-14-2015, 08:13 AM
zj510's Avatar
It has a 245 40 18 on a 9 and a 295 40 18 on an 11
