Old 08-01-2018, 07:58 AM
CJD Automotive's Avatar
CJD Automotive CJD Automotive is offline
Few updates, been swamped with customer cars, so mine takes a back seat as usual!
Had to look back at what I have already posted, and left off at the fuel cell cage. Made the hold down structure:
Then started building the seat structure, which requires a few floor mods:
And at that same time, fit the trans and engine. The driveshaft doesn't clear the top of the loop, so I have to cut it out and extend it.
Which required a new tunnel:
Craig Scholl
CJD Automotive, LLC
www.CJDAUTOMOTIVE.com
"I own a Mopar, so I already know it won't be in stock, won't ship tomorrow, and won't actually fit without modification."
Old 08-01-2018, 08:00 AM
Then built the seat structure and seat mounts:
Craig Scholl
CJD Automotive, LLC
Old 08-01-2018, 08:07 AM
Built the oil tank mount:
And the column mount. Of course a bar is right where I need to mount the clamps to center the column to the seat, so made this standoff piece:
Then on to the pedal mount:
I made the mount will multiple holes, slugged and welded, to allow fore/aft adjustment. You'll notice the column is "inside" the mount with the brake pedal to the left side. This is to allow me to spread the pedals a little wider and keep the accelerator far enough away from the trans tunnel to clear my big ass feet:
The line on the yellow tape is the seat centerline. I set the column and brake pedal to this line. I have the pedals spread for my size 12 4E clown feet!
Craig Scholl
CJD Automotive, LLC
Old 08-01-2018, 08:15 AM
A few things I've had machined.
The first is the ABS tone wheels to fit on the RSRT and Speedway Engineering hub:
Craig Scholl
CJD Automotive, LLC
Old 08-01-2018, 08:26 AM
Rear hubs:
And some wheel spacers. I had Ron supply dimensions for the hub bore to my wheel manufacture when they were building my wheels, but unfortunately he provided the spec for steel wheels. This left me with a rear wheel hub bore about .030" from being hub centric for the drive plate . Talked to Speedway Engineering about turning down the drive plate hub. They told me I could take a 1/4" off without affecting strength! Only needed about .030, so had the drive plate turned down and a steel sleeve pressed on. This solved two problems. Number one, it makes the wheel hub centric, and number two, it allowed me to have hub centric spacers made, but to also pilot the wheel with the maximum thickness spacer. No this wasn't a cheap fix.
Craig Scholl
CJD Automotive, LLC
Old 08-01-2018, 08:33 AM
I'll post up some more later if Photobucket will play nice and let me load some more photos.
Craig Scholl
CJD Automotive, LLC
Old 08-01-2018, 09:52 AM
Ron Sutton's Avatar
Nice fab work Craig. I love the fuel cell cage top with the angle cut top pieces. Nice touch !!!
Ron Sutton Race Technology
Old 08-01-2018, 04:28 PM
Thanks, I'm sure I copied it from something I've seen!
Craig Scholl
CJD Automotive, LLC
Old 08-01-2018, 10:19 PM
Flash68's Avatar
Flash68 Flash68 is offline
Bitchin. The drab green and black look great together.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 08-02-2018, 05:35 AM
Don't forget the fade.
It's Florida and humid as hell. When I finish a section or after I make a part to be welded in, I put it in epoxy.
Craig Scholl
CJD Automotive, LLC
