Old 04-29-2017, 12:18 PM
vstol vstol is offline
Default I give up with brake bleeding
My build is below and I will tell you its not my first build but the most frustrating. I have a Wilwood manual MC and it was bench bled before being attached. I have zero leaks which took a while. I used the mity vac to bleed the calibers but I was getting tiny air bubbles which I thought was from the connection with the hose. I went through a lot of brake fluid but still had bubbles but not the typical air in the system. I put the speed bleeders back on and bled them again. The pedal is still soft. To add salt in my wound I started the car which is on jacks and put it into second gear and stepped on the brake pedal only to watch it continue to spin. I am truly at a loss. This is the first time I have used a Manual Wilwood setup and help out there will be much appreciated. Thanks
https://lateral-g.net/forums/showthread.php4?t=44704
