Old 01-15-2021, 08:26 PM
Nice job, that looks a lot better, and will make your life easier.
The Following User Says Thank You to waynieZ For This Useful Post:
Rodknock (01-16-2021)
  #132
Old 01-16-2021, 08:27 AM
Rodknock's Avatar
Rodknock Rodknock is offline
Thanks Wayne. Today, I'm going to try to do the RS headlight stuff. Get things cleaned up and test fitted.
I didn't want to go to work today, so I had a case of anal glaucoma
John Rodko
69 Camaro RS/SS
Rolling shell, minimal rust.
Heidts Pro G IRS/ Heidts Pro G Front
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
https://www.facebook.com/Angry-Johnn...?ref=bookmarks
The Following User Says Thank You to Rodknock For This Useful Post:
waynieZ (01-23-2021)
  #133
Old 01-23-2021, 08:30 PM
Rodknock's Avatar
Default RS Hideaway headlight stuff
Started messing with the headlight items. Luckily I was able to source complete OEM headlight assemblies from a friend. The OEM stuff is much better than aftermarket. I tried just using an aftermarket bellcrank, and was having issues, so I can imagine what other fitment issues I would have with all aftermarket parts.
You can tell it's an aftermarket grille. Even with the outside lined up perfect the inside area is crooked. Guess I'll have to trim the grille a little.
That's pretty close. Going to need some fine tuning.
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
syborg tt (12-08-2024)
  #134
Old 01-23-2021, 08:39 PM
Rodknock's Avatar
Default Cleaning and painting the RS headlight assemblies
Today I disassembled the assemblies, sandblasted and painted the parts. I have new bushing kits for them, although the original bushings are in great shape.
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
The Following 4 Users Say Thank You to Rodknock For This Useful Post:
Goosesdad (02-01-2021), Roscoe03 (07-21-2023), syborg tt (12-08-2024), waynieZ (01-23-2021)
  #135
Old 01-23-2021, 10:56 PM
Check all the holes some of mine were a little out of round and gave me trouble,if they give you more problems.
They look nice all painted up.
Old 01-24-2021, 05:55 AM
joeko23 joeko23 is offline
That green looks so nice! I just want to bit into that candy apple. Is it a tri stage?
Old 01-24-2021, 08:38 AM
Rodknock's Avatar
The holes are in good shape, luckily. Even the long shoulder bolt doesn't have any wear on it.
It's just 2 stage. House of Kolor Lime Mist. I'm not that talented to do a 3 stage, unless you want to count the sealer before color as a stage
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
Sonar Chief (05-09-2021)
  #138
Old 02-03-2021, 07:53 PM
Rodknock's Avatar
Default RS Hideaway Headlights final fitting
Hopefully these are finished and can be boxed and put away till final assembly of the car.
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
The Following 2 Users Say Thank You to Rodknock For This Useful Post:
  #139
Old 02-03-2021, 08:16 PM
Rodknock's Avatar
Default Hood to fender gaps
Not at all happy with the hood to fender gaps. I guess that's not surprising, considering I haven't been very pleased with much of this build, as far as body gaps go. 🤣
The gaps at the very front and rear are good, but it's like the hood/fenders are bowed in the middle. When I lay a straight edge along the length, I can see some daylight, so it is bowed a little.
I went ahead and added a 1/8" thick piece of metal along the length of the hood, to help close it off.
Hopefully, I can finish it off tomorrow. 14 and 15 hour days at work are taking it's toll on me.🥱
Looser than a hooker on 50 cent night
Ends are good. about 3/16" or a little less
Middle is about 1/4" No bueno
1/8" x 1/2" flat bar, welded along the edge and ground down. Bottom side
Top side
Finish grinding
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
Goosesdad (02-04-2021), Roscoe03 (07-21-2023), streetbird (02-04-2021), syborg tt (12-08-2024)
  #140
Old 05-06-2021, 11:45 AM
Rodknock's Avatar
Default Wheels
WOW!!! Has it been 3 months since I last posted!!?
I've been working pretty much, 7 days a week lately.
Here's a little update. I finally got my wheels ordered, built and received. Mounted the tires on the rear ones. It's a super tight fit, but these pics are with the springs out of the coil overs, and the suspension fully collapsed, which it will never be that far up in the travel, because I will be installing jounce bumpers to keep the suspension pieces from hitting the frame.
Just a little test fit!!! Like a kid at Christmas
Now with the tires. You can see how close to the outer lip, the tire is. It doesn't rub, and like I said, that's with the suspension fully collapsed, and the upper arm hitting the frame
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
The Following 3 Users Say Thank You to Rodknock For This Useful Post:
camcojb (05-06-2021), Roscoe03 (07-21-2023), syborg tt (12-08-2024)
