Old 10-26-2023, 11:00 AM
EVIL SS EVIL SS is offline
We have done this trans mount before on 4 Camaros. No issues so far. Makes a super clean set up.
Do you make mounts or brackets to mount your Recaro seats? Also, are you using 6pt bits? Where have you found it best for the mounting points?
Old 10-26-2023, 11:10 AM
Stielow's Avatar
Stielow Stielow is offline
We make the adapter from the stock seat pan to the Recaro seat tracks. I’ll try to find a photo.
For the sub belt we modify the seat pan to allow for it to be bolted in.
Stielow Engineering
Old 10-26-2023, 01:25 PM
Aschle's Avatar
Aschle Aschle is offline
Thank you for the reply. I am absolutely going to be using that method. Super clean, simple, and it works !!!
On a side note, whoever is doing the welding on the car, is an artist !!!
Jason
Jason Aschle
________________
1969 Camaro
1957 Chevy 150 Utility sedan, semi-pro touring
2016 MB s-AMG E63
Old 11-10-2023, 10:42 AM
Stielow's Avatar
At Sled Alley today.
Stielow Engineering
Old 11-11-2023, 12:15 AM
srode1 srode1 is offline
Shortened the tank? How much will it hold now?
Old 11-11-2023, 05:20 AM
Stielow's Avatar
We will add an extra tank to get the capacity back up to 10 quarts.
Yes we had to shorten to fit.
Stielow Engineering
Old 11-11-2023, 07:11 AM
Steve68 Steve68 is offline
Mark, how level is the car when the sub frame connectors are installed on jackstands??
I have mine within an 1/8 of an inch, was wondering how the guys set that up,
Old 11-11-2023, 09:23 AM
jeff71 jeff71 is offline
Mark,
Why the change in tank locations this time?
Old 11-11-2023, 09:28 AM
Stielow's Avatar
Originally Posted by jeff71 View Post
Mark,
Attempting to keep it simpler. Doing the dry sump tank in the cowl is very cool, but it is a ton of fabrication. Matt and Tom did it like this on Tom’s orange 69. It looked cool and I had a stock 2008 Z06 dry sump tank laying around from an old project, so we did it that way.
This is a cruiser build and not a track monster so not worried about weight distribution.
Stielow Engineering
Old 11-11-2023, 10:34 AM
Stielow's Avatar
Default Hobbs Camaro (Old Drag Car)
New tires.
Trying the Continentals. Michelin quit making a 335/30R18
Stielow Engineering
