Old 11-25-2019, 07:59 PM
Sonar Chief's Avatar
Unhappy Update 11/25
Seems like when I think things are going well .... the ****e hits the fan. Well, since the last update, I got the holes drilled in the dash for the VA outlets. APITA cuz I had to buy two hole saws to get 'er dun.
Since then my AMD fenders came in, I was so focused on the external skin I waited 2 months to get a set with as little 'shipping' damage that I never gave thought that the fenders might BE STAMPED WRONG!!!
So over the weekend I put the fenders on and the driver's side fit as expected, not so bad, but the passenger's side didn't fit fer ****e. After gettin my OEM fender from the shed they didn't stamp it correctly. Go figure, it's AMD ****e Called my AMD rep and he compared his pass fender and it was the same as mine ... so I figured I might as well find out why it's wrong.
For your viewing pleasure ....
It seems the inner brace with the hinges attached was not held in the jig properly and it actually was angled almost 3/4 inch high over the rest of the run to the back of the fender, so I cut out the welds and got her straight over the run.
I didn't have any weld thru primer tonight so I will get some tomorrow. Trying to get the front end together asap to get her to the body shop for some 'front end alignment ' the My Body Man is going to get the doors and the fenders/hood lined up and ready for final bodywork ....
Seems the snowstorm is going to hold things up some which works in my favor, who'd thought that they would stamp them wrong ...... oh yeah,me!!!
Thanks for looking ...
The Following 3 Users Say Thank You to Sonar Chief For This Useful Post:
fleet (11-28-2019), Roscoe03 (11-25-2019), syborg tt (12-02-2019)
  #1452
Old 11-28-2019, 08:58 AM
Che70velle's Avatar
I haven’t bought a ton of aftermarket metal, but for my Chevelle, I had to cut my passenger “new” fender up to make it fit, but it was along the door edge, not along the hood edge. And then I had to cut the drivers fender extension all to pieces to make it fit. I figured that all of this “new metal was this way. I talked to my lifetime painter friend about it before I actually started hacking the stuff up, and he said that it’s all this way, part of the process. My hood did fit good, but it had 2 small dings on it, which was no biggie to me.
Thanks Dad!!
Old 11-29-2019, 01:30 PM
Default Fender misfit!!!
Thanks for sharing ... the AMD parts I have looked over and rejected the rep calls the headquarters and he gets the same old response, "we checked the back stock and they are all like that!" Well, duh ... you are stamping them wrong!
Oh, how's this for fender extension bolt "holes"?
I will call the body man Monday and see what he wants me to do with the fender, thanks for looking ...
The Following 2 Users Say Thank You to Sonar Chief For This Useful Post:
Spiffav8 (12-02-2019), syborg tt (10-23-2020)
  #1454
Old 11-29-2019, 03:39 PM
That's some annoying shizz. It just means that some of the best parts will always be found via junkyard or some dude's stash (or crash), rather than "legit" sources of new parts. Some things just can't be new . . .
Old 11-29-2019, 03:46 PM
dhutton dhutton is offline
The last pair of repop fender extensions I bought fit like crap. Luckily I found some originals.
Don
Old 11-30-2019, 05:21 AM
Mikael A Mikael A is offline
I feel your pain brother, replaced all sheet metal on my 68 Camaro but the roof. It took 2 years and I modified every piece
Mike a
The Following User Says Thank You to Mikael A For This Useful Post:
  #1457
Old 11-30-2019, 07:16 PM
That sucks they weren’t even close. They’ve been making these for how long? And still can’t get it right.
Old 11-30-2019, 08:28 PM
Smile
Don
Repo fenders suck!!!!! Well. I think I can make em better ....
Some clamps and some panel bond ....
That'll do pig!!!
I'll finish the fender tomorrow after it cures ... gotta keep the temps which is hard to do ....
Old 12-01-2019, 10:07 AM
Flash68's Avatar
Flash68 Flash68 is offline
Mike, you are a warrior! Car is coming out great.... keep chuggin
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 12-02-2019, 09:04 AM
syborg tt's Avatar
syborg tt syborg tt is online now
That sucks
marty-mj
