so here are a few pics of the new wiper setup. its still a work in progress, but now all i really need is the linkage from the wiper motor to my new arm and its done. i have an 18" piece of aluminum hex on order from mcmaster and it should be all i need.
so a little vocabulary to keep it all straight. "arm" is the pitman style arm on the motor and the new arm on the firewall. "linkage" is the stock piece from the wipers to the firewall arm and from the motors arm to the firewall arm.
a little background. i originally thought that the motor only spun 180* and then reversed. its the only way my mind could grasp how the motor could "park" the wipers when turned off. i had thought that when turned off the motor just spun backwards a little more sucking them down. i was wrong. using a method still unclear, the motor spins clockwise 360* and then uses a cam action to make the arm longer when turned off. this is how they are sucked down.
so, the original thought was to just rock the new arm back and forth like i thought that the stock arm went. once i found out that it went in circles it posed a slight problem. the new motor would be providing a lateral force, not a rotational one. meaning, if both arms were the same length there would be an issue getting the new arm to pass both 90 and 270 without ripping something apart. since the stock arm was 2.25" and the dse is closer to 2" (still need to call on that), i decided to make my new arm 2.5". this means that my arm will never be forced to make the full circle and instead will just rock as initially intended.
the other issue was the mounting of both linkages on the new arm. i had a few ideas but settled on this one. i had to do some milling to offset the mounting points and to keep the thickness thick enough to tap, but thin enough to keep the stock linkage from pushing too far towards the windshield. the closer to the windshield it gets the more bind that is introduced. this is currently a sweet spot and there is no bind.
here are the pics. like i said, still needs to be cleaned up.
