Old 08-16-2013, 07:12 AM
groovyjay's Avatar
groovyjay groovyjay is offline
Perfection.
Old 08-16-2013, 07:44 AM
Evan Iroc-Z Evan Iroc-Z is offline
I just shorted out my keyboard with all of the drool on it. This car is awe-inspiring!
'89 IROC-Z Turbo 3.8 5SPD
LS1 Brakes|Wilwood Prop Valve|LS1 Master Cylinder|Aluminum Driveshaft|LS1 3.42 Rearend|Adj PHB|Adj LCA|LCARB|Koni Struts|Koni Shocks|Adj Caster/Camber Plates|STB|10 Spoke SS Wheels|PHB Relo Kit|Adj TA|SFC|ARAP Based Prom|B&M Short Shifter|Underdrive Pullies|SMOG!|AIR!|Rag Joint!|Magnaflow|Ported Plenum|Misc Stuff
Old 08-16-2013, 05:44 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Very, very nicley built. Looks like a great car.
We need a drive by video!
Old 08-17-2013, 09:07 PM
Wow !
Old 04-27-2018, 04:54 PM
one fast stang one fast stang is offline
Default Question on the radiator support mod
So much amazing workmanship on this car.
I notice you modified the radiator support so that it is removable. I was thinking of a similar modification.
You have any info on how you did this. I'm assuming you cut the piece out then boxed the open edges then drilled holes and bolt and nut to fasten or welded a threaded nut to screw in to.
Looks like you may have a counter sunk bolt going through the top.
Did you use thicker metal to box it in? guessing two fasteners per side?
thanks for any info, Mike
Old 04-28-2018, 12:15 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
I love this build.
Curtis
Old 04-29-2018, 07:44 AM
Jimbo1367 Jimbo1367 is offline
Default Wow
I don't know how I missed this car for sooooo long. AMAZING. What country are you from? I only had time to sift through the first few pages. SUBSCRIBED
Old 04-29-2018, 09:54 PM
68LS1's Avatar
68LS1 68LS1 is offline
Australia, same shop as my build, https://lateral-g.net/forums/showthre...=45672&page=12
Roger
68 RS Camaro Convertible LS1 6 speed
72 C10 SWB Stepside, old skool 350 4L60e
71 K5 Blazer 350sbc T350
