Old 05-06-2012, 07:46 AM
Track Junky's Avatar
It needs a little more billet.....
Billet and some.......
Gaetano Cosentino
Old 05-06-2012, 09:45 AM
Vince@Meanstreets's Avatar
Hey, that looks pretty cool Vince. Looks like you guys have been busy. Can you post pics of the mounts and firewall area.
not until the frame goes on the table.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 05-06-2012, 12:52 PM
So, just a little insite on what Vince is talking about. The roll center on the stock subframes on first gen Camaro's is 2" below ground. Optimum would be 2" above ground. Vince is going to model a subframe with correct geometry on his computer software and we will rebuild accordingly. After Buttonwillow this year we will be modifying my front stock subframe. We will be modifying the attachment points of the control arms, going to a coil over shock, work on recessing an adjustable front sway bar into the underside of the subframe, and then possibly recessing the modified stock subframe into the car approximately 2".
In the mean time...After my last Thunderhill track day in April I changed my front alignment settings and raised my rear roll center by raising the watts pivot. I couldn't wait till July 1st for my next track day so I will be heading back to Thunderhill on May 19th. Target lap times to be in the 2:04's which means I will need to shave at least 2.5 seconds off of a best 2:07.4 last time out.
Oh, and the LS Vince posted, dont believe it.
Gaetano Cosentino
Old 05-06-2012, 12:57 PM
coolwelder62's Avatar
Any pics of the Pantera?
The pantera owner was having trouble getting the title right.So I think Albert passed on the car.
Old 05-06-2012, 02:40 PM
Flash68's Avatar
Flash68 Flash68 is offline
I wonder... that sounds like a fair amount of work and modification to a stock sub... is it worth it (financially speaking)? I assume the various nice aftermarket subs out there have all this incorporated in, yes?
Man that sucks! I was really excited to see what you did with that Scott.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 05-06-2012, 03:22 PM
Costs will be far less than picking up an after market subframe. The only material items we will need are a bit of steel, a set of double adjustable coil over shocks, and a big maybe on a Chicane kit. I dont see costs going over $1500 and thats including the chicane kit. In addition, time will be on our side as I dont intend on signing up for any events between October and Aptil so Vince will be able to plug in as time allows. I dont think relocating attachment points for the control arms would take more than two days as long as we can keep our noses to the grind stone. lowers will be the easiest as all we will have to do is drill holes and relocate. Uppers will take a little more time as we will have to cut existing attachment point of arm, measure and cut correctly, and then reweld. Shocks will need to be installed at correct operational height and the shock mount tower can be custom or we may do a chicane kit depending on the length of shock dictated in the chicane system. 650 lb coil over springs can be had in a 10" but 700 lb jumps to 12" and I want the 12" option available if needed. My guess is another day on the shock tower assembly.
There is alot of time between now and October and things could change but for now this is the plan.
Gaetano Cosentino
Old 05-06-2012, 04:00 PM
It's kinda good thing,Albert wanted a complete tube chassis,& the car completed for SEMA.I'm a getting old and don't think I am up to that task.
Old 05-06-2012, 05:21 PM
SLO_Z28 SLO_Z28 is offline
Hyperco makes 10 inch springs up to 900lbs (which is a little less than I run). Let us know what you come up with, Im curious what you can do.
James F.
1974 Camaro Z28
Old 05-06-2012, 05:45 PM
In a 2 5/8" I.D. coil over? Thats what I'll need for the Afco coil overs. I'll have to look them up.
Gaetano Cosentino
Old 05-06-2012, 06:11 PM
Hyperco does carry coil over springs in 10" up to 900 lbs but they are 2 1/2" I.D. I imagine 1/8" shouldn't be a big deal. Thanks for letting me know.
Gaetano Cosentino
