Old 02-01-2013, 08:52 AM
syborg tt's Avatar
Hi Guys
Okay drag racers have been doing this modifications for years. Here is an example in a heavily modified 2011 Nickey Camaro.
Name:  2012 01-05 Nickey Camaro Cage (6).jpg
Name:  2012 01-05 Nickey Camaro Cage (7).jpg
Name:  2012 01-05 Nickey Camaro Cage (9).jpg
It's going to be a little tricky, but it's nothing that our interior guy can't handle. We're not putting the cage tubes butted against the roof or anything like that. I think the bigger challenge will be for the painter to get good coverage on the cage.
I bet he still calls you a few names while he is installing the headliner.
Car is looking awesome
marty-mj
Old 02-22-2013, 12:00 PM
Lous69 Lous69 is offline
Recent work at V8TV has included mocking up the radiator, A/C condensor and intercooler along with the custom hood latch assy. to free up the room needed behind the grill for all those cooling devices.
The parts being used include:
2nd Gen radiator module from C&R that includes two fans
Vintage air A/C condensor
Shelby 500 Intercooler with its own two fans.
Volkswagen "THING" Hood latch
It's all still a work in process but the fabrication of the various needed brackets is coming along. We'll post some more pics when the parts are further cleaned up and painted.
We went with C&R's 2nd Gen. F body module instead of their drop in place 1st Gen. module simply because it has more total cooling area.
Once the location of the radiator relative to the core support was determined
a bottom support bracket for the radiator was fabricated. The yellow tape on the core support denotes where the window in the core support was enlarged to allow airflow to the whole radiator core.
The hood latch assembly was mocked up, bracketry made and then mounted.
So.... it's starting to come together. Combination shroud / mounting brackets are now in place.
Since we have so many fans, we want to use Pulse Width Modulation (PWM) fan control of the radiator fans instead of On/Off control.
We don't want the car to sound like a vacuum cleaner unless it's really hot and we need all fans full on.
There are numerous ways to setup PWM control of the fans.
In order to figure out the best way for this application, I started a thread in the engines section of this forum.
There is a lot of really good information and tips brewing over there in that thread.
Here is a link to it: https://lateral-g.net/forums/showthread.php4?t=40215
Old 02-22-2013, 05:33 PM
GeoffP GeoffP is offline
Whoa - HUGE picture alert!
Very cool build - I've been lurking on this one since the beginning and had to post a comment on the roll cage. It's good to see someone thinking through their mods with purpose behind them and not just do something to "be different." Great work on the build so far!
GeoffP
68 Camaro LS1 T56 3.55 12 bolt posi
Old 02-22-2013, 08:32 PM
Sorry for the pic size in last post. I will find out why that happened and fix it.
In the meantime, Thank you and others for your compliments on our build.
To be honest, most of the the fabrication ideas come from Kevin and Trevor.
They take the time to listen to their customer and then propose design options they think will yield the happiest owner experience in the long run.
I've been managing new product development engineers for over 25 years and I've been very impressed with their their thoughtful approach, especially from an engineering perspective.
Old 02-23-2013, 08:14 AM
bonecrrusher's Avatar
bonecrrusher bonecrrusher is offline
How much room did you leave between the GT500 intercooler and the radiator?
2005 LeMans Blue Corvette w/ T56 & Z51 & C6Z06 Brakes, Build Thread: https://lateral-g.net/forums/showthread.php4?t=27408
2005 GMC Sierra 2500HD - LLY - Allison
2014 Chevy SS - LS3 / 4 Doors
Old 02-23-2013, 10:04 AM
Without driving to the shop and measuring, from memory and review of the pics above, I would say nominally about 4 inches or so between the intercooler and the radiator.
The intercooler is the first item in the stack behind the grill. The intercooler fans are "puller" type so they logically reside between the intercooler core and the A/C condensor.
Behind the A/C condensor is the radiator core support. The radiator is mounted to the back side of the core support.
Kevin and Trevor had to juggle a lot of requirements to get everything mounted in an optimized way without violating any constraints.
For instance, they had to leave enough room for the one off, custom grill assembly my son Dan designed.
They had to completely redesign the factory hood latch assembly and bracketry (using builds like JackAss, Red Devil, etc. for clues)
We will be using a stock looking front spoiler that also deflects air up into the heat exchangers.
We will also be using custom, one off hood louvers to further enhance air flow through the heat exchangers.
If you look closely, you will notice that the V8TV team strives to minimize weight while providing function (as evidenced by the holes in the radiator support shelf for instance).
As the owner of the car and one who likes to tinker, I also appreciate how they plan the design of everything they fabricate down to the fastener level so I will be able to take things apart and put them back together without having 3 hands. Whenever possible, they design brackets with captured nuts and/or threads so installation and removal of parts is typically a one sided operation with a logical sequence.
Old 02-24-2013, 10:35 AM
Thanks for the info - yeah I can see a lot of planning would have to go into that small package.
I was kind of thinking of getting that gt500 fan setup and install when I get around to buying/installing the Edelbrock blower kit for my LSx motor in the Vette.
Old 02-25-2013, 08:40 AM
RussMurco's Avatar
RussMurco RussMurco is offline
Originally Posted by Lous69 View Post
The front, 6 piston calipers
The rear, 4 piston calipers:
Whoa! Glad I saw this, I had no idea that the Wilwoods had no dust-boots on the calipers!
Russ "Murco" Murray
http://i1339.photobucket.com/albums/...psc7bc7b5c.jpg
"Liquidating excess cash through the automotive hobby!"
Old 02-25-2013, 10:34 AM
I know Wilwood offers a line of brakes that do have dust boots.
I'm no brake expert but I think you might find that the highest performance product offerings from several brake companies utilize seals vs. dust boots. I'm sure they have good reasons for doing so.
Of course, each person needs to select the parts that best meet their specific needs and purpose. No one design is necessarily better than the other until the use of the product is considered.
OEM applications typically use dust boots so I would guess the reasons you want dust seals mirrors what the majority of people desire for their applications.
Old 02-25-2013, 11:14 AM
RussMurco's Avatar
I couldn't agree more! My Firebird won't be hounding the Stielows, Pozzis, or Tuckers on autocross tracks and will spend 99.5% of it's life on regular roads where I plan to drive in all sorts of traffic and weather conditions. That means lots of dirt, dust, moisture, and brake dust so these wouldn't be a good choice for my build. Your car is way beyond anything I'm building, and I love it!
Russ "Murco" Murray
