Old 03-25-2015, 08:07 AM
Nice arms, Craig--they should avoid possible buckling issues. How far did the lower coilover mount wind up being below the actual arm? When I was mounting my RideTechs, it wound up being kind of a ridiculous challenge trying to figure out how to get optimum travel (on a relatively short-stroke shock), a 30% or so sag quantity, and a mount for the t-bar lower that wouldn't break. I think the lower mount wound up being about 1.5 inches or so below the arm. They took the beating at Thunderhill pretty well, I think...
One of us definitely needs some good paint--it's good that you'll be the one to take responsibility for cosmetics...
Old 03-26-2015, 09:12 AM
craig510's Avatar
craig510 craig510 is offline
I got the rest of the parts last night, so I should be in good shape to have it together for autoX action this weekend.
Old 03-27-2015, 09:05 AM
Panteracer's Avatar
Panteracer Panteracer is offline
Default 63 Falcon
Craig,
good to hear you are going to be ready
Save me a spot by the Trees
Bob
Old 03-27-2015, 09:16 AM
Originally Posted by Panteracer View Post
Craig,
Bob
I bring my own shade..... LOL
Old 03-27-2015, 12:30 PM
Justin@EntropyRad Justin@EntropyRad is offline
Default Awning
Does yours get tied down as well, Greg? We had a trailer with similar setup, only it had verticals into buckets of concrete...the winds at Road Atlanta ripped it off, with myself and another guy holding onto it, and it landed on an M5...ouch
Old 03-27-2015, 12:34 PM
Nothing holding it -- it's purely hanging out there. It is self retracting in a wind. Has a mercury type "windy O'gauge" set up on it end of it. When it moves too much she rolls herself back up.
Old 03-27-2015, 01:13 PM
Default Awesome
That would save a lot of apologies. Luckily the guy with the M5 was someone we were doing track prep for, and saw us get lifted off the ground before the awning tore...a pdr and a buff and he was good
Helped that we works for Firefly Vodka, and we all "forgot about it' later on
Old 03-30-2015, 09:48 PM
craig510's Avatar
The car worked excellent at Goodguys this weekend. It took me 4 runs to figure out it was better to leave it in first and bounce off the rev limiter than bog in second, and I never found the limit of grip. It was nice having a car that I felt like I could have won with. I finally started feeling the tire again on Sunday. If I can get more seat time this season I will be right there, cranked out a 62.377 on my last run which is 3 seconds faster than I was at the last show. I couldn't believe how much better the car was. Mike's quote for the day was "its amazing what good shocks and a little geometry can do"
I can't share the exact numbers, but the shock mounts a little over 1" below the center line of the UCA (just enough room for a craftsman deep socket) and as far out as possible. We are using custom JRi shocks with 4.75" of stroke. The motion ratio is 74%. The old Maier racing arms were closer to 65%, and a stock 65 mustang is about 54%. We did a lot of work with JRi on the shocks to optimize packaging and performance.
Engine bay view. Double adjustable require a remote canister to keep the nitrogen volume happy at full compression.
I did a couple of special things to the reinforcement plates because I know I will be playing with the shocks a lot. I welded the nuts to the bottom side so I don't need 2 wrenches, and I added two 10-32 tapped holes so I could screw the plates to the body.
I countersunk some existing holes so the hardware is hidden by the mounts when installed.
All done and ready for autocross action. I will remove the lower bump stops when I install the new lower arms. Right now, the strut rod would bottom out on the frame before the shock shaft bump stop hits.
Old 03-31-2015, 06:20 AM
jarhead's Avatar
jarhead jarhead is offline
this is awesome!
joe
Semper Fi
My 68 Torino
Old 03-31-2015, 06:36 AM
Busts me up Craig! It's SHOCKING to know what good geometry and some JRi's do for handling. We're all learning a fairly steep curve now that Pro Touring is evolving into pro racing. Just buying brand name parts and bolting them together isn't nearly the same as getting people involved that actually know suspension.
Good for you!!! Love this build... and love the way you're continuing to go about your business.
