Old 01-12-2016, 05:58 PM
Terryd's Avatar
Terryd Terryd is offline
Cool ride Joe! Nice to be different. When I was a kid back in the seventies my aunt had a red '68 FB with a white interior. She was a hotshoe in her day. Killed my uncle since he was a die hard Mopar guy. LOL ! That Torino left quite an impression on me.
Terryd
Check out the latest project at:
http://www.67novaproject.blogspot.com/
'67 Nova SS clone PT
'06 Z06 - Sold
'72 Trans Am - sold
‘73 Trans Am - Poncho Powered PT build
Old 01-13-2016, 06:57 AM
pro66tour's Avatar
pro66tour pro66tour is offline
Progress is awesome Joe! I have a soft spot for Torinos and Galaxies.
Loving this build...
Old 01-13-2016, 08:42 AM
jarhead's Avatar
jarhead jarhead is offline
So pretty! Will you be painting it Ford blue, Joe?
It's already gunmetal grey, going with a theme
Joe
joe
Semper Fi
My 68 Torino
Old 01-13-2016, 08:43 AM
jarhead's Avatar
joe
Semper Fi
My 68 Torino
Old 01-13-2016, 08:44 AM
jarhead's Avatar
joe
Semper Fi
My 68 Torino
Old 01-13-2016, 03:03 PM
Panteracer's Avatar
Panteracer Panteracer is offline
Default Torino
Joe,
I bet you get a lot more the 500hp out of that
engine mostly due to the compression... should be fun
Nice build
Bob
Old 01-13-2016, 04:09 PM
jarhead's Avatar
Thanks Bob, I am excited
joe
Semper Fi
My 68 Torino
Old 03-23-2016, 02:36 PM
jarhead's Avatar
It has been a while since I updated this...
I had 9 days straight to work on the sheetmetal and had to go back to work Tuesday.
I don't have allot to show as I had not expected how long it would take to cut 1 million spot welds
I started by cutting out the driver side floor pan, and toe kick.
I did some rust prevention using POR15 on the "so called" frame rail.
My transmission mounts were only spot welded on, I guess that how they did it in 1968. I ran some beads in several places so I didn't have to worry about ripping them off when I dump the clutch .
I set the floor pan and toe kick in place and did some more marking. I have not tacked them in yet because I need to make a pattern to use for tunnel replacement.
joe
Semper Fi
My 68 Torino
Old 03-23-2016, 02:39 PM
jarhead's Avatar
I was tired of messing with the floor so I moved on to removing the inner fender well to tub it.
I had to drill out all the spot welds on the inner support and remove it for later modification.
Back to cutting
I was a happy old Jarhead when this came out in one piece as I am trying to modify it. They don't make tubs for Torino's, just Stangs,and Camaro's lol.
On to clean up the so called frame rail, and check for rust.
A trunk shot...
While I was inside the fender well, I removed metal that covered the rocker, and a piece of the inner fender that was toast. I found allot of dirt and junk in the rocker.
The inner fender piece will be a real pleasure to make
I purchased 69 Torino fender extensions (on the left). i didn't care for the 68's (on the right).
I now have to spin the dainty barge 180 in my small shop so I can get to my welder. Hopefully some more progress will happen soon
Joe
joe
Semper Fi
My 68 Torino
Old 03-24-2016, 06:18 AM
Nice job Joe, keep picking away at it!
