Old 02-18-2020, 03:00 PM
Sonar Chief's Avatar
Smile Update 2/18
Dang it's been cold here ... but managed to get some of this and some of that done. In no particular order ... installed my + battery cable pass through,
worked on my VA wiring harness, finished wiring the main power to the Entropy fan controller, dressed up the Dapper Lighting LED harness
, tore down the radiator fan assy. for powder coating,
installed my OEM door handles and measured the lock cylinder [AMD skins] for filing,
and oh yeah, installed the repro hood hinges .... that's it for now!
Thanks for looking ...
The Following 2 Users Say Thank You to Sonar Chief For This Useful Post:
jarhead (02-19-2020), Roscoe03 (02-19-2020)
  #1492
Old 02-18-2020, 09:51 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
You're making some great progress despite the snow and cold. I'm really enjoying this thread!!
Curtis
Old 03-26-2020, 09:01 PM
Smile Update 3/26
Thanks, buddy, I'm trying my best!
Been some time since I updated this thread ... been doing this and that when the temperature cooperates, which has been difficult this winter. My hand surgery has been pushed out til ... who knows when, so I just keep on keeping on and do what I can with what I can.
The pandemic has Aurora going crazy, not to worry though, got food and TP so get to work on the car when I can get the temps up ... supposed to get more snow Friday, grrr ...
So where were we, oh yeah, I ordered a Wolf Fab 4.5" shrinking disc to get the fender patch back to original contours. It seems no matter how careful you welding are there is still going to be some distortion and this shrinking disc is the cat's pajamas.
Had a crown in the fender patch as seen below
with about ten passes with the disc the fender is mo better ....
It does take some time to shrink the metal but wow what a difference
Since I was doing some body filler I figured I might as well do some other low spots that needed attention, man this body work is hard work and messy but anyway this is what I get done so far ...
Oh yeah, I pushed the car to access the passenger side and dented the quarter panel on the card table, so I had to fix that with a hammer and dolly and some filler ... the card table is NOT in the garage any more!
I did get a headlamp bucket recondition kit but the plastic inserts for the horizontal and vertical adjustment broke .... so I'll work on the front end and get the electrical all sorted out this week I hope.
Thanks for looking and keep being socially responsible ....
The Following 4 Users Say Thank You to Sonar Chief For This Useful Post:
jarhead (03-27-2020), Roscoe03 (03-27-2020), syborg tt (10-23-2020), waynieZ (04-02-2020)
  #1494
Old 03-27-2020, 05:06 AM
RdHuggr68 RdHuggr68 is offline
Looks like a lot of neg. camber in the right front wheel dolly!
Old 03-27-2020, 06:58 AM
Cool
Just an optical dillusion
Old 03-27-2020, 07:52 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
How did you like the 4.5" disk? I have their 8" disk and its helped me out a ton with my roof.
Instagram- camaroaj
Old 03-27-2020, 09:08 AM
The 4.5 was just right for the lower fender. I never used one so I watched a lot of videos and knew not to rush the heat and cool cycle for best results. I didn't use air or water to cool just time and the results were great.
The Following User Says Thank You to Sonar Chief For This Useful Post:
jarhead (04-02-2020)
  #1498
Old 03-29-2020, 06:05 PM
Smile Update 3/29
Been in the house for a week and when the temps are good ... it's Camaro time!!
The goal was to get the front end wiring verified with installed equipment and power, well that was the goal ... seems my AAW headlight switch is defective. I cannot get the switch shaft to lock in the headlight switch ...grrrr.
So working on the Dapper lighting LED 7", the lights were great it's the mounting hardware that went south, seems the plastic inserts for the adjustments were brittle and broke on me, ordered more Friday ...
Anywho, I worked on the grille assembly today to only find the powder coater smashed the upper grille assembly mounting flanges closed. So I straightened it mostly to get her installed but she'll need more tweaking ... the simple stuff that kicks your arse!!!
So glad I bought my OEM grille assembly back in '98 (Ummm $79.95) and this is the first time she's been mounted (that sounds awkward) but things lined up pretty well ...
The beauty shots ....
Really liking the blacked-out look of the grille and headlights ... now if I can only get power to them Thought I had the screws for the headlight bezels but I can't find them right now ...
Thanks for looking...
jarhead (04-02-2020), orangevert (05-23-2020), Roscoe03 (03-30-2020), syborg tt (10-23-2020)
  #1499
Old 03-29-2020, 07:29 PM
Gmachine1911's Avatar
Gmachine1911 Gmachine1911 is offline
Looks great, I love the look of the dark headlights! You might double check me, but if I remember right from when I did my AAW kit, AAW made a big deal about installing their headlight switch, specifically with regard to the knob/shaft Assy. Not sure if that helps but might be worth an internet search to see about any special tricks. I don’t recall anything especially different when doing mine, but thought it was worth a mention. Your progress is amazing, keep up the good work!
Shane
#theanchorholds
Link to my 68 Camaro build thread:
https://lateral-g.net/forums/showthread.php?t=56387
Link to my 67 Nova build thread:
https://lateral-g.net/forums/showthread.php?t=57769
The Following User Says Thank You to Gmachine1911 For This Useful Post:
Sonar Chief (03-30-2020)
  #1500
Old 03-30-2020, 08:40 AM
Goosesdad's Avatar
Goosesdad Goosesdad is offline
Looks fantastic!!
Have a great day!
John
My Build Thread:
https://lateral-g.net/forums/showthread.php4?t=53320
The Following User Says Thank You to Goosesdad For This Useful Post:
