Just a quicky story about EFI installation and the "troubles with EFI" that people rag about all the time...
I dropped off a 383 stroker I'm having built for my brother in laws blown pro street Camaro at a shop that are all friends of mine. They have two EFI jobs - one a buddy/customers 8 stack EFI with EZ EFI - the other a 306 Ford in the owners Ranchero with the complete EZ EFI throttle body etc.
They're having "issues" with both cars... the 8 stack will fire and run - pig fat - and then dies when the plugs finally foul out. Blowing black smoke -- etc.
The Ford won't idle worth a dang - surging - dies when put in gear - and is just generally unhappy.
The installer is telling me that the IAC is 'bad' and this and that and the other thing -- it was all the "EFI wasn't worth a dang..."
On the 8 stack - Brian Macey (FAST EFI University) finds they have the "default" 74 # injectors selected -- when the car runs 36 #'s.... AND there is no vacuum to the vacuum referenced pressure regulator. DOH! Fix those two issues -- fires right up - idles fine. It's an INSTALL problem - NOT the EZ EFI.
I'm looking at the FORD -- and again - they have chosen poorly on the set up screen.... when they should have just selected the "FAST EZ EFI" - they choose custom set up and put in the wrong injector size. Had they chosen the right EFI system.... it would have known what injectors they are using etc. I input the correct information in the set up after choosing "new base tune"....
I also found that they were trying to do a "work around" in setting the TPS. Since they couldn't get WOT physically - they were setting the TPS throttle closed position - and when the ECU asked for WOT position - they were disconnecting the throttle linkage and opening this by hand. Thus "cheating" the linear setting the ECU was looking for. Then they'd reconnect the linkage... which would pull on the Throttle body at a different rate than the ECU was seeing. I told them - You can't CHEAT.
So when we got those couple of things handled --- I asked about the timing... as it was still surging and died with put in gear (automatic). A timing light showed me 33* at idle with the vacuum hooked as they had installed. Without vacuum - it was at 10*....
A quick check shows me they have the vacuum t'd into the MAP sensor line. DOH! I reconnect this to the PORTED vacuum port.... which drops the timing at idle to the 10* (which I then bumped up to 14*). Motor smoothes right out - and no longer dies when put in gear... and off we drive to do the EZ tune... the owner is THRILLED by the end of the 25 minute drive. The motor purrs... has great throttle response and runs like it should.
The moral of this rant ---- It was all LOFT! And lots of it! It was never the EFI...
