Old 08-04-2011, 10:33 PM
Jtomas801's Avatar
Jtomas801 Jtomas801 is offline
Hey, Mike, saw the pictures on bangshift. Good job at making some headline news! Unfortunately, I don't have any updates. I have been working nights and weekends. But, I have been thinking and planing some of my next steps on the car.
I also traded a friend a bunch of stuff for a car trailer, just need to paint it to make it look good.
Thanks,
Jon
Old 10-10-2011, 12:45 PM
Jtomas801's Avatar
Well I haven't had time to work on the car lately, been helping my Dad work on the house. Stuff like change the electrical panel out and a bunch of other things, so the roof can be redone before it starts raining again.
But, I have made a big purchase, I bought a set of Ridetech triple adjustable coilovers from Scott (coolwelder62). I called Scott up Sunday a week ago, figured out what I needed, and got the coilovers on Saturday, that's fast service. I got the 5.2" stroke for the front and 6.3" stroke for the rear.
I am trying to figure out what I want for springs, but at the moment I am thinking about 600 lb in the front as I will be running the amc engine. At the moment I have 200 lbs springs for the rear as I was going to mount the coil overs vertically, but now I am going to mount them on an angle. For the rear I'm thinking about picking some 250 lb springs.
I will have to say, these are really awesome looking. One nice thing I like is you get a lot for your money, ridetech sends you the bearing spacers and reducers for 5/8" and 1/2" bolts, and you get the remote reservoir mounting clamps. Other brands just give you the coilovers and you have to purchase all that stuff separately.
Here is some quick pictures with my lack of photography skills:
Thanks,
Jon
Old 10-10-2011, 12:53 PM
Bryce Bryce is offline
Nice purchase.
Old 10-10-2011, 12:56 PM
Jtomas801's Avatar
Thanks Bryce,
Have you got a chance to get to an autocross with your car yet?
Jon
Old 10-11-2011, 06:40 AM
coolwelder62's Avatar
Jon,it was great to get a chance to visit w/you on the phone last sun.I was I really belive in the qualtiy of the ride tech shock's and chassis componet's.Thank's Scott M.
Old 10-11-2011, 07:09 AM
Originally Posted by Jtomas801 View Post
Thanks Bryce,
Jon
Not yet, I had a baby last month so my priorities have changed. I have been driving the car and enjoying it on the street.
Old 11-09-2011, 10:03 PM
csangster csangster is offline
Default Strength Calculations
Okay, so it sounds like its trying to find a rod that will support the load more than the bolt (5/8 or 3/4)
I am trying to learn a little bit of this, so if you see any thing wrong please let me know.
While searching through google, I found the equation for shear strength:
tensile strength pounds/in2 x cross sectional area.
In the case of a -10 an bolt with a tensile strength of 160,000 psi and a cross-sectional area of 0.306640625 in2 at the full diameter
160000 pounds/in2 x 0.306640625 in2 = 49062.5 pounds
If 49062.5 pounds is single shear, you double it to get 98125 double shear, right? That should be the amount of force to shear the bolt?
Thanks,
Jon
Good evening,
Let me first say that I am extensively impressed with this build thread and all of the modifications. I have been wanting to build a Javelin just like this, and yours is one of inspiration..........very nice.
In a small effort to help make sure you build goes off well, I feel compelled to tell you that the above strength calculation is incorrect (I am a registered Professional Engineer and I perform these types of calculations for a living).
You are mixing your strength numbers when performing this calculation.
If you are trying to determine the load carrying capacity of your fastener in shear, you need to use the shear strength of the material, not the tensile strength. These are two entirely different measurements. The good thing is you can look on a website called MatWeb, find the material in question and it will give you nearly everything you need to know about that material, CTE, yield strength (tensile and shear), ultimate strength (tensile and shear), thermal conductivity......the list goes on.
The next thing you are missing is your factor of safety. You need to carry a factor of safety on your design to cover anything that you may not have thought about or considered. Generally, you can pick a factor of safety from 1.1X all the way up to 16X or more.........it just depends on how much risk you think you can take. For a suspension component, a factor of safety between 2 and 4 is a good place to start......the Carroll Smith's book that was mentioned earlier will have a better guide for selecting the factor of safety for your application.
As far as single shear vs. double shear is concerned, the shear strength of the fastener is what it is, when the fastener is in single shear, you are loading only one shear plane in the fastener, when the fastener is in double shear, you are loading two shear planes, thus doubling your strength of the fastener in shear.
While you are looking at shear strength of the fastener, keep in mind that the fastener is also stressed in bearing, you will need to make sure that the bearing surfaces don't have too much stress in them and causing plastic deformation of the fastener or the suspension components.
Additionally, the above calculations are all static calculations and do not apply to dynamic load cases. Sometimes you can increase your factor of safety if you are unable to properly calculate the dynamic stresses in a joint.
Dynamic stresses are important because they can cause failure by fatigue of the material, not by failure at the ultimate strength.
I'm rambling too much, I just wanted to make sure you taking everything into consideration for your build so something doesn't break on you and give you headaches later.
Again......very impressive and inspirational build.
Cheers,
Chris
Old 11-10-2011, 06:19 AM
Jon,I hope the shock install is going well for you. Scott M.
Old 11-10-2011, 12:08 PM
Jtomas801's Avatar
Originally Posted by csangster View Post
Good evening,
Cheers,
Chris
Thank you very much for the information and the nice words. I am going to have to research this a bit more. I believe that the Lateral Dynamics 3 link uses 5/8" bolts with 5/8" hole and 3/4" shank, so at least I know that set up is tested and works.
Thanks again,
Jon
_______________________________________________
Jonathan Feltis
69 AMC Javelin - Back in Progress.
Old 11-10-2011, 12:20 PM
Jtomas801's Avatar
Shoot, I haven't touched the car in a few weeks but I have been working making some money. This weekend I am working Saturday and going to the NHRA finals on Sunday. Hopefully after we get a couple of these big jobs done I can get back working on the car in a couple weeks.
I hope Summit racing has some good coupons again like they did last year, I am thinking about getting a t-56, or if I can make up my mind on what front brakes I want to get.
Again Scott, congratulations on your latest build, the car came out great and it sounds like it performed really well for the lack of testing on it. I can't wait to see what the next build looks like.
Thanks,
Jon
Jonathan Feltis
