Old 07-20-2013, 12:38 AM
MX145 MX145 is offline
I changed the look a little from stock. I may add a flange to the sides to make it tie in a little better with the style of the stamped cross members. I'll see what it looks like in primer first.
Old 07-20-2013, 12:40 AM
Here's the "finished" support ready to weld in. I still might add a flange to both sides.
Old 07-24-2013, 11:40 PM
New wheels are ready.
Old 07-25-2013, 07:35 AM
Great job on car! Keep it up. Wheels are beautiful
Old 07-25-2013, 08:39 AM
Thanks Al!
Old 07-25-2013, 10:06 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
you sure are doing great work on your car,also I really like those wheels
Old 07-25-2013, 12:36 PM
Ricochet's Avatar
Ricochet Ricochet is offline
What an undertaking!! Awesome job! Look forward to seeing this one come together. I don't think you'll go wrong with either color. Grey is and has been played a lot - but there is a reason - it looks killer! Tough call! Good luck!
Brent
Old 07-25-2013, 06:49 PM
DaleTx's Avatar
DaleTx DaleTx is offline
Nice job on the build... the wheels look great
"If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
Old 07-26-2013, 12:48 AM
Flash68's Avatar
Flash68 Flash68 is offline
Ryan, you are kicking some proverbial ass....
I like that blue with those wheels.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 07-26-2013, 04:42 PM
Sonar Chief's Avatar
Been keeping an eye on your ingenuity with your suspension and frame mods .... question, looks like most of the metal you are adding is 3/16", is that correct? How bout the subframe connectors?
Nice work, I'll be lurking in the background .....
