Old 01-14-2019, 07:42 AM
New THREE gallon dry sump tank mounted..... and it’s mounted NOW behind the protection of a NEW front wheel tub.... You can only imagine the amount of track debris that was being thrown against the firewall — and anything back there....
Sent from my iPad using Tapatalk Pro
Old 01-14-2019, 07:46 AM
Hard to see from this photo - but this is the new front tub looking back from the front of the car.... I’d be happy with that quality of fabrication on a fancy build!!!! Remember this is a race car - plain and simple.... I like their (SpeedTech) craftsmanship!!
Old 01-14-2019, 08:04 AM
Blake and I were just discussing the whole “PCV” system and vacuum pop off valves etc.... of course he has been in direct contact with A.R.E and Kurt Urban.... both of whom know their way around these systems.......
Had Sutton bothered to do this while building the car —- it might have saved me a few grand.... and even more important to me —- MY TIME.....
The Following User Says Thank You to GregWeld For This Useful Post:
fleet (01-14-2019)
  #154
Old 01-14-2019, 08:07 AM
71RS/SS396's Avatar
How you plumb the topend of the engine is really dependent on the scavenge ability of the pump and whether it can maintain vacuum on the crankcase when the engine is wound up. If you can't maintain vacuum when the engine is at max rpm you have to vent the crankcase pressure to somewhere or you're going to have blow-by issues.
I started out with a 3 stage Dailey that made vacuum at idle but with the 4.125 stroke crank I have it couldn't maintain vacuum when we revved it up. I added 2 more scavenge stages, I can now maintain 15" of vacuum at 8,000 rpm and picked up 20 hp. I initially ran it sealed but with street driving I started seeing moisture accumulation in the tank oil cap and the valve covers. I plumbed a -4 line from the drivers side valve cover to the top of the tank to turn the air over and cured the moisture issue.
What I have done with the 3 stage pumps is to run one -12 line from the valve cover to the top of the tank, you can run it to the tank breather but you'll just fill with oil quicker.
The Following 2 Users Say Thank You to 71RS/SS396 For This Useful Post:
frojoe (01-15-2019), GregWeld (01-14-2019)
  #155
Old 01-14-2019, 08:21 AM
71RS/SS396's Avatar
Gdub I would get rid of that Y point by the "B" in your drawing and run each valve cover line separately to the tank, once you go through that Y it's only flowing what one line can flow.
Old 01-14-2019, 08:41 AM
CJD Automotive's Avatar
CJD Automotive CJD Automotive is offline
What did you guys change on the front clip? I see a newly welded in piece.
Craig Scholl
CJD Automotive, LLC
www.CJDAUTOMOTIVE.com
"I own a Mopar, so I already know it won't be in stock, won't ship tomorrow, and won't actually fit without modification."
Old 01-14-2019, 08:45 AM
I would put a pop off on the valve covers to the tank. Does the same thing, except allows the pump to pull a vacuum on the crankcase until it can't!
This can be plumbing inline to the tank from the valve covers:
http://www.petersonfluidsys.com/engi...WayPopOff.html
Craig Scholl
CJD Automotive, LLC
Old 01-14-2019, 09:05 AM
71RS/SS396's Avatar
That's certainly not a bad idea.
Old 01-14-2019, 11:21 AM
Blake Foster's Avatar
took out the bent 1x3 and replaced it with a straight piece to give room for the gussets we added to the lower control arm.
Blake Foster
www.speedtechperformance.com
The Following 2 Users Say Thank You to Blake Foster For This Useful Post:
BMR Sales (01-15-2019), CJD Automotive (01-15-2019)
  #160
Old 01-14-2019, 02:41 PM
LS7 Z/28 LS7 Z/28 is offline
It would really be awesome to see detailed photos of what you’re changing suspension wise, so that those of us who have the same suspension are able to see what you’ve come up with as a safe “repair” or change to the front lowers, 3 Link rear, etc. This build thread is sort of the only source that the rest of us might have for ideas and knowledge on what we should do. I understand if you guys can’t share all of it, but anything helps. I personally don’t know anyone to go to that I can trust for a redesign. Thanks again for sharing Greg/Blake.
The Following 3 Users Say Thank You to LS7 Z/28 For This Useful Post:
DBasher (03-29-2019), frojoe (01-15-2019), GregWeld (01-14-2019)
