Old 07-06-2021, 08:21 PM
syborg tt's Avatar
Originally Posted by ScotI View Post
That's an excellent idea. I do that when jotting down notes & measurements during initial phases but will add that to the mix where applicable.
Thank you.
When I took the car apart (both times) I bag / blue tape the parts and take pictures so when I start putting the car back together I can go back and look at my pictures on the day I took the car apart. It helps jog my memory as it pretty much sucks since Chemo back in 2012.
marty-mj
The Following User Says Thank You to syborg tt For This Useful Post:
Damerjo (07-07-2021)
  #1602
Old 07-30-2021, 02:16 PM
syborg tt's Avatar
Default Vintage Air Coolant Lines (( 03-14-21 ))
Finally finishing up the Vintage Air heat lines.
Yes something is really really wrong with me
For mock up I am using this plastic reducer.
I can't wait till I don't have to touch this valve again.
marty-mj
The Following 2 Users Say Thank You to syborg tt For This Useful Post:
fleetus macmullitz (07-31-2021), Goosesdad (07-31-2021)
  #1603
Old 10-03-2021, 12:53 PM
syborg tt's Avatar
Default Vintage Air Firewall Fitting (03-13-21)
I missed this one so I am going back to it.
Here is the ground stud that I will be using on the passenger side of the car. It goes directly to the battery and it will be also be a brass bolt.
Firewall fitting test fitted it one last time before I permatex it to the firewall.
Way back somewhere in this thread I put the part number for the machine washers that I am using on the inside of the firewall.
All glued in and nice and tight.
marty-mj
fleetus macmullitz (10-09-2021)
  #1604
Old 10-03-2021, 01:10 PM
syborg tt's Avatar
Default Upper Radiator Mounting Hardware (03-15-21 )
Headed back to Ace Hardware for the tenth time this week.
03-21-21
Time to get out the big drill.
marty-mj
fleetus macmullitz (10-03-2021), jarhead (10-04-2021)
  #1605
Old 10-03-2021, 01:21 PM
syborg tt's Avatar
Default Passenger Door Hinge Bushings, Yes I hate my life. (03-19-21)
This is those while I am here moments.
If you know what these are you now how much this project sucks.
I made the right decision by buying the correct tool to remove the spring which made this a much easier task.
I also made sure I drilled reference holes so I could the hinges back in the same place once I removed them.
New bushings installed and on to the next hinge.
Upper hinge should be much easier.
I have said a bunch of cuss words at this point.
Back to Ace hardware...good news I found some chunky bars.
marty-mj
camcojb (10-03-2021), fleetus macmullitz (10-03-2021)
  #1606
Old 10-03-2021, 01:25 PM
syborg tt's Avatar
Default DEI Heat Sleeve on Transmission Lines ( 03-20-21 )
Since the transmission lines are close to the downpipe on the header I decided to wrap the lines in DEI Heat Sleeve.
Looking at these hard lines I now know that I am going to have to paint them.
Just one more thing to add to the never ending to do list.
marty-mj
  #1607
Old 10-03-2021, 01:36 PM
syborg tt's Avatar
Default Drivers Side Hinge - Ugh (03-21-21)
So this side didn't go as smoothly as the passenger side.
This tool is a life saver.
Hinge is off and reference marks are set.
This side was not fun.
Both hinges are installed and lets just say the door is way off and I needed a break.
So I off to the taco joint!
I called it a night when I got home and I even broke my rule of cleaning up every night.
marty-mj
  #1608
Old 10-03-2021, 01:39 PM
syborg tt's Avatar
Default I needed something easy to do I made an AC line. (03-22-21)
Since yesterday didn't go so well I decided to make an AC Line.
I plan to crimp the fitting in the engine bay once I have all of the lines in the car.
marty-mj
Old 10-03-2021, 01:51 PM
syborg tt's Avatar
Default Notch-Head Brake Line Clips (03-31-21)
Time to installed the Notch-Head line clamps. Drilling the hole in the frame with the itty-bitty drill bit is very very scary.
marty-mj
  #1610
Old 10-03-2021, 02:12 PM
syborg tt's Avatar
Default Misc Blue Tape Notes
So I started making notes on the car for things I need to address.
I also need to plug this holes since I am planning on using the Wildwood electric parking brake calipers.
I will be using this wire when I install the Fessler RS light in the RS modified upper valance.
I also need to extend the line as my goal is to hide/clean up as much as of the wiring I can behind the grill.
marty-mj
