Closed Thread
Old 07-16-2010, 01:42 PM
I like it alot better so far. If I we're to guess, the pedal is about 15% -20% harder. Let me get a race and more miles under my belt. The pedal ratio is 12:1 for a manual brake set up in a 69. Most reccomend a minimum of 8:1 for a manual set up with the proper master cylinder. I personally feel the 7/8 is undersized for the caliper piston volume. I wish I would've done this 2 years ago.
Tyler is correct, I did use them. Thanks Frank. My only regret at this point is not slicing the tunnel for more trans to tunnel clearance. When I had the old steel block in the car I also had the coil over adjusters as high as I could physically get them. (Small block springs) I was able to back them down a turn or two for the aluminum block. I thought them LSX motors were light?
  #1662
Old 07-16-2010, 04:23 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Very cool Todd!
Congrats on the ink!
  #1663
Old 07-16-2010, 10:22 PM
Good to hear Todd!
Funny -- when we were at RTTC -- I talked for awhile with the Wilwood rep there. His statement rings very true - which was - "some people really like a high hard pedal a 1" M/C gives and some like the softer more modulated feel of the 7/8". He said he personally liked the "feel" of the 7/8... but it doesn't matter as well as it's what YOU like!
  #1664
Old 07-16-2010, 10:25 PM
I don't have any choice if I want a decent pedal. Yes, I like it very much. This whole big lip, 335mm, race car, blah, etc, blah, forces it. Most guys can get away with murder. I can't because I push the limits!
  #1665
Old 07-16-2010, 11:06 PM
awr68's Avatar
awr68 awr68 is offline
Originally Posted by Teetoe_Jones View Post
He did. He won't again. It causes.... Issues.
Tyler
Yep! Me too! Had to raise the trans tunnel .75" to fit the T56......
Tony
'68 Camaro
  #1666
Old 07-16-2010, 11:07 PM
awr68's Avatar
Glad you are finally feeling better about the brake system Todd...these things can take some time!
Tony
'68 Camaro
  #1667
Old 07-17-2010, 09:02 AM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Tyler
I nominate you for understatement of the week, sir. every little issue I have now seems to be related to those stupid bushings. They do make the car look very cool though.
Todd, apparently my little LS is more of a boat anchor than your ZL1. I'm currently shaving fiberglass off of Tyler's prized inner fenders when going around hard turns. Maybe I need to make an upgrade in the engine department, hell the sound alone would be worth it.
Matt
  #1668
Old 07-17-2010, 09:13 AM
awr68's Avatar
Matt
Matt, can't you go with a 1" or so taller coilover....or just a longer spring alone if you are running out of adjustment? It too me a couple trys to get it right with the desired ride height when I modded the stock frame with a DSE kit. If I remeber right I had three sets of springs before I nailed it!
Are your lower control arms level at your current ride height?
Now back to PB!!
Tony
'68 Camaro
  #1669
Old 07-17-2010, 12:43 PM
Matt
I'd be surprised if you would coil bind the springs spinning them up higher. I bet you only need a turn or two. You can get a rough estimate by measuring the distance between all the coils and available shock travel. You may need a mechanical advantage. Take off the wheels and get some more leverage on them with a wrench or short pipe. Running low has it's compromises. I'll take a compliant package over looking cool anyday. Find a ride height that works well on the track and street and record it. It's normal for your car to have settled out.
I wouldn't trade my big block for an LSX. Not in a million years.
  #1670
Old 07-17-2010, 11:16 PM
89 RS's Avatar
89 RS 89 RS is offline
Todd, I'm a little behind on the site and getting caught up now. The new house/garage looks awesome, great space. The taillights look great and congrats on the ink in the mags.
Corey
1989 Camaro RS
Closed Thread
