View Poll Results: What engine will you be using?
SBC w/ EFI 42 6.99%
SBC w/carb 98 16.31%
BBC w/ EFI 41 6.82%
BBC w/ carb 50 8.32%
LSx 205 34.11%
LSx w/ forced induction 80 13.31%
Other 70 11.65%
SBC w/ EFI & Forced Induction 15 2.50%
Voters: 601. You may not vote on this poll
Old 07-01-2014, 02:09 PM
Twoblackmarks...'s Avatar
Twoblackmarks... Twoblackmarks... is offline
In the future this poll would have changed SBC to "gasoline engine" or maybe "internal combustion engine".... HeHe.. And the others would be "lipo" "AA" "Parallel wired 9volt" "Duracell" or whatever is hot in the Electric world now..
There is a lot of Electric cars here in my country now....
I have a Pontiac With a Pontiac in it, Round port exhaust Alu heads and Roller Cam. A Holley on the top too
Old 08-18-2014, 08:59 PM
68Cuda 68Cuda is offline
Mopar 440, 0.030 over with Ross light weight flat tops, zero deck height, 0.990 pins, Eagle rods, stock forged crank. Block has had a few oiling mods. Milodon road race pan with trap doors for oil control.
Edelbrock RPM heads with 75cc chambers (closed chamber) and a little bit of porting. Heads are on order, should have them in about three weeks.
Ultradyne solid NF62 grind. This cam has ramp rates that are designed to take advantage of the 0.904" Chrysler lifter size (it opens valves faster than engines with smaller diameter lifters are able to). This cam has a 270 advertised duration, 243 @ 0.050, but more duration @ 0.200 than most roller cams that have 243 @ 0.050. Cam only has gross valve lift of 0.548".
Mopar super stock six pack intake. Part number P3690982. Made by Weiand in the early 70's for Mopar to sell through the dealers as a "legal" super stock intake. Runner volume and length optimized for the 440. I purchased this intake off E-bay and sent it to F&B performance to convert to port EFI. Throttle bodies rated at 1900cfm.
Crank trigger wheel built into ATI SFI balancer. MSD crank trigger pick up. MSD distributor converted to send cam sync signal. MSD box to light the coil, XFI 2.0 system to tell the MSD what to do and control the pulse width on the injectors.
Pictures below are mock ups when we were fitting the hood over the engine and air cleaner. Air cleaner will be painted orange top / black base. May even put the 440 6bbl sticker on top. Heads in the pictures are my old ported iron heads.
This combo of cam / heads / intake will make a LOT of torque between 4k and 6k rpm. Put that in a 3200 pound car with 3.90 gears and a T56 six speed and it should move, right? With this cam, iron heads, an edelbrock RPM dual plane intake and a Barry Grant carb this car ran 90mph in the 1/8th mile with a 3 speed automatic and a mild convertor. With the change in heads it will pick up 50+hp on flow alone, then bump compression up 1 point, add this ram intake and EFI? It should be interesting. With aluminum heads and intake it should weigh close to small block Mopar weight.
Michael
Plano, TX
1968 Barracuda Notchback
Body & Paint:
http://www.forabodiesonly.com/mopar/...dy-2014.10252/
Engine:
http://www.forabodiesonly.com/mopar/...ictures.10230/
Old 10-22-2014, 03:01 PM
captainofiron's Avatar
captainofiron captainofiron is offline
that has to be one of the coolest intake/EFI set ups I have seen
Old 10-22-2014, 04:02 PM
carbuff's Avatar
carbuff carbuff is offline
Who makes those 2-barrel throttle bodies? Thanx!
Old 10-22-2014, 07:53 PM
http://www.fbthrottlebodies.com/
Both of you are Pontiac guys in the Austin area. I lived there from 1993 to 2006...
Michael
Plano, TX
Body & Paint:
Engine:
Old 10-22-2014, 08:05 PM
Thanks! And it somehow fits under this little hood!
Michael
Plano, TX
Body & Paint:
Engine:
Old 11-25-2014, 01:06 PM
71455Formula's Avatar
71455Formula 71455Formula is offline
Pontiac 455HO. Compression bump to 9-9.5. Roller cam and Fast Ez EFI. Should put out enough grunt to have fun with.
1971 LS5 Firebird Formula with a 6 speed(Finally drivable)
2013 GMC Sierra(sold)
2000 Formula Ws6 6 speed(miss her!)
Old 11-25-2014, 08:48 PM
Wow it looks like a beautiful car.
Old 03-21-2015, 06:08 PM
TBART70 TBART70 is offline
548 ci BBC injected
Old 04-07-2015, 08:25 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
I am going to use an LS3 (418 CI) with an LS9 supercharger. The dyno results were 841 hp and 816 ft/lbs of torque at 10.9 psi. No testing at 15 psi, but Dave Mikels stated around 930 hp. .
