So it’s been a long couple of nights. I ordered and received the map sensor for the motor to complete the engine side of the wiring other than the coil packs. The port on the sensor was to big so I had to drill the hole on the intake to 15/32 and it fits good now. Just have to extend the wiring for the plug.
The brake lines have showed up from inline and I needed a couple more fittings so I’m waiting on the "T" that goes on the rear axle and the hold down clips for the frame. Then I will run the lines and bleed the system. Also waiting on the radiator to show up which should be soon. To complete the motor side of things I've started to piece together the intake with what I'll need and that will be ordered soon. Other than that just have to figure out what I’m going to do for exhaust. I really wanted to have side pipes, 3" ovals is what I was thinking but due to lack of room, expense I may just run dumps before the rear. We’ll see.
The main power source on the drivers firewall is complete. All main power wires have been ran and tightened. I need to finish up the gauge wiring, couple wires on the ecu, run relays for the headlights & fans when they get here and some miscellaneous stuff and that should be the rest of the wiring. I’ll be glad when that day is. Not too much longer before the car actually is able to fire.
Timmy came over last night as I really wanted to try to crank the car and check for leaks and make sure I had oil pressure. The main thing that still needed to be done was the main ground straps needed to be hooked up. One for each side of the frame to body, and one from the engine to frame, one in the rear for the main battery hook up, and a small one under the dash for ecu, gauges..ect. Instead of drilling and using bolts on everything I had him bring the welder and he welded the bolts right to the body/frame. This way there is one less thing to come loose and it’s a much better connection. While he did that I finished up the wiring for the starter and did the temporary wiring for the oil pressure gauge to see what was going on. After all the grounds where hooked up we gave it a go and everything went well, other than a small oil leak at the adapter that screws into the intake. I need to take it off clean it off and put some teflon tape on any pipe treads. It was a relief to finally here it turn over and confirm that the wiring so far is correct. Now it’s time to get the rest of the stuff buttoned up so I can actually fire it. Once I fire it up Ill only let it run for 30-60 seconds as it has to be broken in. I talked to my chevy dealership that I bought the motor off of and he said if I take the car to a certified mechanic and have them go over it and break the motor in I can gain back all the warranty that I have lost while the motor was sitting. So that’s what I'm going to do. I talked to a shop called Injection connection and they are going to go over the whole car once complete, break the motor in per the GM instructions, change the oil and strap her to the dyno. I want to start the car to check for leaks, make sure everything is working so I’m not paying shop rate because I have a leak in a fuel line..ect. Anyway here is a quick video and some pictures from the past few days.
http://s18.photobucket.com/albums/b1...t=d3205b82.mp4
