Old 03-31-2012, 08:06 PM
makoshark makoshark is offline
Well, it shouldn't take a day or so to get here
If all goes well, they will be installed tomorrow
Old 04-01-2012, 08:52 PM
Sonar Chief's Avatar
Thumbs up Making a mess
sanding the quarters! I didn't get the door prepped, IAW POR15 if you let it dry overnite you have to rough the skin with a scotch brite and then you can topcoat. I'll rough it up this week and take it to work and get some black on the door.
So plan B, get the quarters down to metal and see if there are any surprises under all that paint. Chemical and mechanical stripping started and I almost finished in one day ... Just some touch up left and when I get the wheel houses going and the patch I can start body working the rear half.
Needed two rounds to get it down to metal
Still needs some work
Driver's side looking better
So ... not too exciting but it's progress, I put the trunk lid on for trial fit - pretty good fit.
Not bad for 45 year old quarters
Thanks for looking
Old 04-01-2012, 09:13 PM
coolwelder62's Avatar
Look's Good, I am lovin your progress.
Old 04-01-2012, 09:50 PM
Thumbs up
Thanks for noticing ... little at a time and then she's done!
Old 04-02-2012, 07:55 AM
Nice progress. They look really good , you must have felt happy seeing those in that shape once the paint was all off.
Old 04-02-2012, 08:50 AM
Thumbs up
Thanks ... I was very happy to see the quarters in bare metal knowing I don't have to replace them
Old 04-02-2012, 09:34 AM
Bucketlist2012's Avatar
Bucketlist2012 Bucketlist2012 is offline
A little at a time......then you will be Done...Keep at it..
Luck is the meeting of preparation and opportunity
Pro Touring 71 Z/28 in training
Soon to be crazy
Old 04-03-2012, 02:22 PM
Thanks for the Those words are so true ... so I keep plugging away!
Old 04-03-2012, 09:29 PM
Default Update 4/3
Well I'm glad I didn't put away the heater, it was snowing this morning and I needed it tonite in the garage. Finished the quarter panels and did both door jambs. While I was removing the paint on the rocker panel I came across a hole? I think while I was discing the hole came through, there is a repair I need to do - glad I found it now!
Cleaned both door jambs
Hole that needs attention
My Great Dane came out to see what I'd been doing all nite.
More to follow .... thanks!
Old 04-03-2012, 09:36 PM
Is your car an RS?
