Old 09-06-2007, 06:29 AM
Payton King's Avatar
Default Your car looks great!
I would rather not talk about your woody, but if we must...
So tell me about your fuel cell. Do you have to run an external pump? Will you be able to connect it to your gas door or will you need to open the trunk to fill it? I guess you will need to pass the fuel lines through the trunk floor and also the vent tube? What about the gas smell in the trunk passing into the driver's compartment? Thinking about doing this at some point and I like you being the test pilot for this set-up.
I do know from personal expierence that you will get a gas smell that will permeate through braided line and at the fittings. I think XRP makes some fuel line that will not let the gas smell through, but it is a machine assembled and you have to give them the measurements to make it for you. I am sure that it is cheap.
I am looking forward to seeing you and your car at SEMA!
Old 09-06-2007, 07:03 AM
68protouring454's Avatar
russell will permeate, xrp or aeroquip will not, i have experienced this some, and kenny davis use's aeroquip or xrp line all the time for full fuel lines on hot rods
Jake's Rod Shop
Old 09-06-2007, 07:29 AM
Steve1968LS2's Avatar
I odered my Sportsman take with an internal Bosch pump. I could hook to the external fill spot but I chose not to.
The fuel line, return line and vents will all pass through the trunk floor using XRP bulkhead fittings. The rest of the tank is sealed so no gas smell should waft forward. I have a bulkhead behind the seat area and I will add one to the package tray.
Regular XRP braided line didn't sweat gas and had no gas smell. I've heard that Russle line will. I've found the XRP fittings to be superior to all other fittings I have dealt with, then again they are the most expensive.
See ya in Vega$
Originally Posted by vinz68
What kind of gas cap is that?
There's not one on yet.. will be (was before) the "Larry" gas cap ( www.billetfiller.com )
Old 09-06-2007, 09:25 AM
Diognes56's Avatar
Diognes56 Diognes56 is offline
Looks great . Glad to see it coming back together .
David
Old 09-06-2007, 09:49 AM
Default Not get off track here
but I have the aeromotive fittings and they must use the russel hose, because I am getting a gas smell. I thought I need to put a charcoal canister on the vent line, but the lines themselves smell.
Now back to our regularly scheduled program...
You can if finally coming back together and the photos look great. 2 more questions and I promise to stop.
1. Why did your rims go back to Forgeline...did you move the fronts in another 1/2 inch?
2. When do you think it will be back on the road?
Old 09-06-2007, 10:22 AM
Yea, I had the offset increased to 7-inches
I will have the car back by Oct 1st.. then it just needs the interior done which will be simple.
Then SEMA.. then the road.. lots of road
Old 09-07-2007, 07:04 AM
GvEman's Avatar
GvEman GvEman is offline
Awesome paint man! I would love to se it live at sema, but thats not a possibility=( At least i get to se some pics of it!
Keep it roling!
Old 09-07-2007, 10:00 AM
vinz68's Avatar
vinz68 vinz68 is offline
Thanks for the link for the gas cap. You will be at pigeon fordge right.Looking forward to meeting you . And you'll get see my car in person. I'm gonna try to get to sema and check out Bad Penny. You car is killer
Vinnie
www.fquick.com/vinz68
Old 09-07-2007, 10:37 AM
Your car is at SEMA.. you HAVE to go "experience the moment"..
68s will dominate SEMA this year.. no mercy!
See ya at PF.
Old 09-12-2007, 06:28 PM
Ok.. progress pics...
Today was "final buff" day.. the next step will be re-assembly and install of the new gas tank (and plumbing).. Two weeks till I have it back
Best Of Show Coachworks hard at work...
From the back:
