Old 02-20-2014, 12:22 PM
bonecrrusher's Avatar
bonecrrusher bonecrrusher is offline
So this past weekend I got the radiator and fans in, the intake, and the rear coilovers in.
This week I drained the transmission fluid relatively easy and couldn't figure out a way to refill the t56 still up in the car.
I ended up using a really old cheap fluid pump that I bought like 10 years ago to drain a fuel tank - I didn't think it would work - but it got the ATF into the trans with no problem.
I then installed the Kooks X-pipe, reconnected the Corsa axle back - and tightened everything up.
I tried to fire up the car last night - but the battery is dead - so by tonight I expect to get it up and running!
I still need to adjust the coilover ride height - and then reattach the rear swaybar as the rear is lowered and the endlinks won't line up anymore.
Now for some pics:
2005 LeMans Blue Corvette w/ T56 & Z51 & C6Z06 Brakes, Build Thread: https://lateral-g.net/forums/showthread.php4?t=27408
2005 GMC Sierra 2500HD - LLY - Allison
2014 Chevy SS - LS3 / 4 Doors
Old 02-27-2014, 12:56 PM
Well I tried to fire up the car last week - and I got it running for a couple minutes and it was running like absolute garbage.
With the 60 lb injectors nearly being double the stuck LS2 injectors - it was throwing a ton of gas into the and out the exhaust.
So I decided to have the car towed up to the tuner as I didn't want to risk messing up the motor. They are tuning it now - and I should get it back next week - I really am looking forward to finally driving this thing!
Also before having it towed - I lowered the car down onto my race ramps and was able to get the rear swaybar attached - I will have to fine tune and readjust it after I get the car back.
Here are some pics of the car on the lift - and of the 3" Kooks long tubes and X pipe.
Also for my birthday - my girlfriend got a set of 2" tripod stands that I will be able to use under the lift - they are from Greg Smith Equipment.
They are made in China - and some of the hardware is pure garbage - I stripped one of the bolts putting it together - so I got some better hardware from Lowe's.
I have seen some people support entire cars on these - I know that I wouldn't - but I would have no issue putting a rear axle or hold up an exhaust pipe or two with them.
Old 03-05-2014, 05:37 AM
I picked up the car last Friday from the PCM of NC - they had no problem tuning the motor with all the parts that I had added.
They did a dyno tune, and tweaked it on the street as well.
Here are the final dyno numbers - I have to say that I am more than happy.
For 6 weeks of work and doing it all by myself - I can't complain about picking up ~120 hp at the crank.
I previously dyno'd my car and it made 375 at the rear wheel - now its making 450!
Also - here is a video of the LS9 cam idling - it has a bit more lope than stock:
PCM filmed the last dyno run - so I should be able to post that in a few days.
Old 03-05-2014, 08:21 AM
Like I said - here is the chassis dyno video!
Old 03-05-2014, 04:14 PM
Che70velle's Avatar
Great job man! Nice numbers you have there.
Thanks Dad!!
Old 03-05-2014, 04:22 PM
glassman's Avatar
glassman glassman is offline
6800 redline? Sure sounds nice!!!! Watchin dyno video's never gets old.....
Mike
Old 03-05-2014, 06:46 PM
6800 - guess thats where they cut it off.
The lifters and fuel are good for it.
Only thing that would really hold back would be the valve springs.
Old 03-17-2014, 05:56 PM
I finally got the Corvette all finished up - the Kooks midpipe was rubbing against a heat shield on the gas tank.
I had to loosen the shield - move it over just a tad - and also bent the tab a bit upward to make room - no more rattling when I first fire the car up!
I finally got the first fire up video off of my GoPro - mind you the car wasn't tuned yet and was on the stock LS2 tune:
I finally took down the lift - and put all my tools/parts away - two get 2 cars parked back in my garage.
A few weeks back my G8 got backed into by my neighbor - she managed to crush both doors on the drivers side.
I took the car to the body shop and it got repaired.
Ever since I got the car back the front suspension was making a creaking noise when I turn the wheel - and I took the car to the dealership for an alignment - and the tech couldn't get the wheel straight.
So at that point - still having a car payment for 2 more years - and having no more warranty - I decided to talk to the sales guys and see what they would offer me for the G8.
After going over this purchase in my head for a few hours - they gave me a good deal, and my rate on the new car was lower then my g8 was!
I ended up lowering my monthly car payment by a hundred bucks - so I ended up taking my car in for an alignment - and went home in a new car.
Here is what is in my garage now:
Some pics of the G8 next to the SS:
If you notice - I kept the CTS-V wheels and brakes - I haven't decided if I am going to put them on the SS yet - we'll see.
First thing I need to do is add Homelink to the car - I actually removed the visor that I modified in the G8 - and I am going to put it in the SS.
Yes the colors are different - but it should plug right in.
Old 03-17-2014, 06:18 PM
Jon69RagTop Jon69RagTop is offline
Default Nice upgrade
Love the new color, white is awesome for a daily driver.
Old 03-17-2014, 07:11 PM
89 RS's Avatar
89 RS 89 RS is offline
Nice work on the Vette, sounds good. How do you like the new SS? Those SS's look like they are pretty nice.
Corey
1989 Camaro RS
