Old 05-07-2012, 09:15 PM
Ron in SoCal's Avatar
There's more than changing the lowers going on there I think. First you took a balanced car and played with it - wider tires, spacers, different alignment, different watts link (roll ceneter) settings. I also think the lowers changed the game from where you were as well. Now you're chasing a ghost - it's not there anymore.
The suspension engineers from Dick Guldstrand on have taken the stock sub and gone as far as they can. The vendors each have their version of what works best. Many won't agree w me, but I think in our segment, Corvette geo gets copied most. This gets you to a wider tire and a better camber curve aka contact patch. I'm no engineer, but I don't think that's gonna happen w the stock sub. You also have not yet experimented w a true coil over set up w your favorite shock angle/spring rate/sway bar. All this needs to be dialed in.
There's alot smarter guys on here than me, I'm just just spitballin'...
Ron in SoCal
69 Camaro in progress
Old 05-07-2012, 09:26 PM
Track Junky's Avatar
My understanding is that the Gulstrand mod allows for more camber gain in compression and also will allow for more caster. Tubular control arms give us more caster and camber but not more camber gain in compression which I'm thinking the Guldstrand mod will pick up.
I'm not clear on what moving the lower control arm would do. If I go through it in my head, raising it and moving it out will give more camber gain but what else?
Gaetano Cosentino
Old 05-07-2012, 09:27 PM
Flash68's Avatar
Flash68 Flash68 is offline
Thanks for the props bro but I dont think I'm fast.
I don't either pal.
Well it's a pretty decent matzo ball.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 05-07-2012, 09:35 PM
Vince@Meanstreets's Avatar
Thanks for the props bro but I dont think I'm fast. I look at guys like Carl Chicca and Dave Brown and think those guys are fast. Although I do think that those guys having the funding and years of track time over me is definitely a contributing factor in their success.
What confuses me.....I look at photos of my car on the track when my Torque Thrusts were on it and my tires look flat on the asphalt and tire wear was even across the fronts. It never pushed either.
Once I through on the vette wheels, lower tubular control arm, and changed my alignment settings everything went to ****. So I'm back to square one. I'm honestly hoping that my alignment setting are the contributing factor to the car pushing. May 19th I'll be running at T-Hill again so I'm hoping the recent changes I made will fix the push.
Fill me in on what you know about moving the lower control arms
At that time, with so many changes you had made makes it difficult to pin point the cause.
Watts changed your RHC. We have to do the calculations on where you optimum spot will be. Setting up your front end again will allow us to put the front where it needs to be. Right now I suspect your front and rear are fighting each other. We will get there, we need to work together again and get that trust back. Adding a G mod at this time will only complicate things.
Baby steps guys, otherwise expect to pay more for something you may not have needed in the first place.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 05-07-2012, 09:39 PM
You're running GW lowers right? Although a fan of their stuff, there's a guy on PT that had a huge proplem w them. He had to change uppers/lowers out to SPCs (Marcus helped him) to get his wheel centered in the well. He also changed his spinde but I don't think that was the problem. IMHO not every vendor's lowers place the spindle/BJ in the same lcoation.
To answer your question, I don't know of any lower that adds caster and most vendors don't advertise their caster/camber changes.
Ron in SoCal
Old 05-07-2012, 09:40 PM
I don't either pal.
Hey you're on a roll Bro! See what getting engaged will do to improve your personality?
Ron in SoCal
Old 05-07-2012, 09:42 PM
...Adding a G mod at this time will only complicate things.
Exactly where i was going...
Ron in SoCal
Old 05-07-2012, 09:45 PM
Flash68's Avatar
Ouch!
2014 4 tap Keezer
Old 05-07-2012, 09:52 PM
Ouch!
That's your ol' lady pinching you for spending too much time on this site. Welcome to the club...
Ron in SoCal
Old 05-07-2012, 09:53 PM
Flash68's Avatar
Correction. You mean spending too much $$ as a result of this site.
2014 4 tap Keezer
