Old 05-24-2013, 04:13 PM
parsonsj parsonsj is offline
Dale,
I was working on the exact same information. I agree that either should work fine, and I am resting easier myself since my project's drivetrain is all bolted up and installed in the car.
Thanks!
John Parsons
Old 05-24-2013, 04:14 PM
garickman garickman is offline
Originally Posted by DaleTx View Post
John, I found out some info on the dimensions for the for the LS1 and LS9 slaves. I contacted Katech and they said the ZR1 LS9 slave is 2-3/8” when compressed. I went to an auto parts store and measured an LS1 slave for a 2002 camaro (AC Delco #386433, Summit #24264182) and it was about 2-1/2” when compressed.
It looks like either the LS1 or LS9 slave would work. The plumbing is slightly different on the two slaves, and the ZR1 slave has a rubber boot covering the spring and the LS1 slave did not… I’m not sure what other differences there might be.
Good news! Thanks for the update Dale. Pretty cool that you took the time to find out this info even though your ride is done. Much appreciated.
Greg
Old 05-24-2013, 09:33 PM
DaleTx's Avatar
DaleTx DaleTx is offline
Originally Posted by parsonsj View Post
Dale,
Thanks!
No problem guys...
Be sure to report back how you like the clutches... I'm sold on the set up. It's hard to beat the OEM stuff. Super smooth engagement and firm grip.
"If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
Old 05-24-2013, 10:09 PM
I'm running the same ZR1 clutch in my Z06. I've got about 300 miles on it, and it's great. Smooth, easy on the leg, etc. No hint of chatter or anything like that. I'm a big fan of OEM clutches too.
John Parsons
Old 05-30-2013, 11:59 PM
DaleTx's Avatar
Default track day prep
This week I registered for a track day out at Portland International Raceway at the end of June… can’t wait to get back out on the track with the new engine and transmission.
I made a few other mods to the car recently to get ready. New wider front rims and tires... replaced the Bilstein shocks with Hotchkis Tuned Fox shocks... and I modified the exhaust system with new mufflers and larger diameter tailpipes.
Here is a shot of the new 9" wide rims. The old rims were 8".
I went with Nitto NT01's 255/40/ZR17 which is 10.35 inches wide (about 5/8" wider than what I had before). I added some adjustable stops on the Global West A-arms so I could prevent the inside of the tire from rubbing on the sub frame rail.
I took about 60 LBS off the front off the car with the new engine and increased the footprint of the front tire... this should help to balance out the handling and reduce the push some.
One other thing I want to do is mount a fire extinguisher to the DSE 4 point roll bar on the upright. Not sure what most guys are using... open to ideas.
Mario Andretti
Old 05-31-2013, 05:13 AM
rickpaw rickpaw is offline
Dale, I'm using a mount from Scott Drake (bought it from CJ pony parts).
http://www.cjponyparts.com/scott-dra...r-mount/p/FEM/
Tu
Old 06-19-2013, 10:38 PM
DaleTx's Avatar
Default fine tuning and tweaking
Over the past few weeks I have been doing some fine tuning on the car since I have finished the main job of installing the new LS engine, dry sump pump system, GM ECM, new fuel system, T56 magnum trans, and LS9 ZR1 twin disc hydraulic clutch set up.
Here is some of the stuff I have been working on… I changed out the 2-1/2” tailpipes for 3”. There was a noticeable difference... the engine breathes better now and the exhaust tone is deeper.
I replaced the Bilstein shocks with the new Hotchkis Tuned Fox Shocks
The shafts on the Fox shocks are larger diameter than the Bilsteins
The new shocks feel good on the street... not sure how they will work on the track yet... we'll see this Friday.
I brought the car in to have the camber, caster, and toe set up. I went with 1.5 degrees negative camber, 5.5 degrees caster, and zero on the toe
Next... I installed some new bling!... Katech carbon fiber valves covers
Next up... the new Halon fire extinguisher set up, and new digital tach with shift light. It's nice to have all the hard work behind me now so I can finally enjoy the car...
Mario Andretti
Old 06-19-2013, 11:13 PM
Sieg's Avatar
Sieg Sieg is offline
Dale - Absolutely beautiful!
Old 06-20-2013, 12:04 AM
Ron in SoCal's Avatar
Way to go Dale! Looking forward to your impression of the shocks and if the valve covers meet your expectations.
Ron in SoCal
69 Camaro in progress
Old 06-20-2013, 01:16 AM
fleet's Avatar
fleet fleet is offline
X2!
