Old 07-30-2013, 02:07 PM
carbuff's Avatar
carbuff carbuff is offline
Originally Posted by Payton King View Post
No flow numbers on the heads...the guy that did them ran a TRD (toyota) program on them and they do not want the numbers out.
Payton, I'm confused... You are using SB2 heads, correct? Or did I miss something along the way? If so, how/why would a TRD CNC program (I'm assuming by program you meant a CNC porting of the heads) work on these heads?
I'm assuming I missed something obvious...
Old 07-30-2013, 04:27 PM
Heads and block look killer Payton. My wife thought I was checking out some nudie pictures when she heard me say beautiful! I used to love hearing my 69 Z/28 humming up to 8000, Music to my ears...
Old 07-30-2013, 07:05 PM
byndbad914's Avatar
byndbad914 byndbad914 is offline
I like the rod to stroke ratio for that rpm requirement, 1.72 is solid.
Just curious what is more important on a race / track car. Horsepower or Torque ???
throw in my .02, worth maybe a penny... and specific to road racing, not drag racing.
keep in mind that HP is a multiplied number with torque the basis of the math and a multiplier of 5252, so it is basically a math measurement - dynos measure torque and then do math to quote a HP number and this is also why HP always equals torque at 5252 rpm.
HP = Torque x RPM ÷ 5252
Keeping that in mind, you want the most torque you can get in the power band that you are going to use which tends to start looking like HP since race cars operate at high rpm. So while the torque seems low in an F1 car, the HP is huge because it is multiplied by such a high rpm value - that said, that is the powerband they want to use to get the most overall power out of that engine combo so they are technically maximizing the engine for max torque in that powerband.
The way I have always tried to do it is have the car make max torque near the bottom of my rpm range -500rpm and max HP at the top rpm. So if I am going to shift at 8500rpm and my rpm drop is 1500 rpm with a race trans, I would want max torque around 6500 rpm with the torque curve as flat as possible up to 8500 rpm with the max HP around 8500. You don't want it to be too peaky of course as there will be turns where it is better to go below the band and "lug" out of the turn than shift and 1 second later shift again.
Point = while a slightly smaller cam might make a higher torque number at 6000 rpm than the bigger cam at 7000 rpm, may be even flat as hell from 4500-6500, and appear to only rob a little HP at 8000-8500 rpm, it does absolutely nothing for me on a road course because I will rarely use the power below 6500 rpm, maybe that one turn that it is easier to lug the engine than to downshift only to upshift a second later.
So, as an example, my current engine combo for my road race car - I wanted to use a tappet cam for longevity which limits the rpm a fair amount, which then adds to component longevity with springs, rods, so forth as higher rpm is higher loads on these parts. I have 7 years on this engine with zero rebuilding and it is just now starting to use oil and puff a little smoke, so I have gotten a lot out of it
Max torque = 5000 rpm with max HP at 7100 rpm. That is a 2100 rpm band. I had a 1500-1700 rpm drop on my shifts, so at 7100 rpm I would drop to 5400-5600 rpm which is peak torque + 500. If I felt like lugging a turn down to 4500 rpm I would, but I don't optimize for that. I could run out to 7500 rpm with no issues if it was required to run deep into a turn, but generally I shifted around 7K and dropped to around 5500 rpm.
That all goes out the window if you demand 2500 rpm drops of the trans, which then requires a much broader powerband from 5500-8500, but a spread that wide on shifts is a bad idea for a number of reasons, not just powerband.
Old 07-30-2013, 11:29 PM
Flash68's Avatar
Flash68 Flash68 is offline
is 3.600. Trying to limit power curve to 8500...which just sounds stupid.
396 cubic inches... nice number.
and yeah it's stupid... stupid awesome.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 07-31-2013, 05:44 AM
Payton King's Avatar
Default Bryan
You are not missing anything as I asked the same question. Apparently the Chevy, Ford and Toyota head intake runners are all the same in Cup but everyone has what they think is the best program for the port work....learn something new every day.
Also learned after they run a race they pull the heads off and have a CNC machine that will do another valve job on the head and only take .002 off the seats. Crazy race stuff for sure at that level.
I need to go back and do the calcuations, but Ed told me 415.06 CI
Old 07-31-2013, 05:51 AM
Ron in SoCal's Avatar
Don't fall out of your chair, Dave's math is correct.
Ron in SoCal
69 Camaro in progress
Old 07-31-2013, 06:49 AM
Default I figured it was
too lazy to work a calculator. Guess I can put 396 Camaro badges on my car now.
Old 07-31-2013, 07:39 AM
carbuff's Avatar
Well that sure is interesting... I wonder how that works? The SB2 heads have been around for a while, and Toyota is relatively new to the sport. So I'm curious how that is done from a design perspective...
Thanx for the info!
Default Now you have me thinking
Cubic inch calculation=3.147 x radius squared x stroke x 8
piston bore 4.180
stroke 3.60
395.89 CI
Old 07-31-2013, 05:51 PM
byndbad914's Avatar
Default another easy formula so you can use bore diameter
3.1416 (pi) x bore squared x stroke x 2.
That said, I am assuming you have a 9" deck height on the SB2? If so you would have a 1" compression height on the piston?
9" deck - 6.2" rod - 1.8" (stoke/2) = 1" CH
that is a short piston Every time I would build up a 347 Ford (stroker 302) which has a 1.1 CH I would always think that piston seemed so short. The good news is your rod to stroke ratio as I mentioned before is better than a 347 and even tho' a 347 wasn't all that bad (1.59) they would rock the pistons a fair amount in high rpm engines and wear the skirts. I suspect having less side load from the longer R/S will help keep the pistons from rocking so much. I am a big fan of R/S values in the 1.7 range if you can't already tell. It does definitely keep the piston weight down which is good at 8500 rpm
Heck, the LS7 has nearly as short of a piston and much worse R/S and I bought a car with one so what do I know hahaha. 'Course 8500 rpm isn't in my future anytime soon.
