Old 04-19-2018, 11:14 AM
SSLance's Avatar
SSLance SSLance is offline
So, how do you all like this?
Lance
Old 04-19-2018, 02:52 PM
Just don't drop a tiny nut......
Looks great Lance!!!
Old 04-19-2018, 03:47 PM
Panteracer's Avatar
Panteracer Panteracer is offline
Default New Shop Design
Lance,
Floor looks great.. you won't hardly have
to clean it to look good
Get yourself a good flashlight as Greg is right
every time you drop a small bolt or nut it will be
hard to find.. I have the fleck epoxy floor so I know
Glad you are going to finally be able to move things in
and get settled
Bob
Old 04-19-2018, 06:04 PM
********** correction **********
DO NOT DROP ANY SIZE NUT OR BOLT ON THIS FLOOR.
GIDDY UP!!!!!
Old 04-19-2018, 06:10 PM
SSLance's Avatar
I'm gonna go drop a nut on it right now...just to see!!
With the white walls in there I am very impressed with how bright it is with just the few lights so far.
Lance
Old 04-19-2018, 07:48 PM
jarhead's Avatar
jarhead jarhead is offline
didn't you guys nuts drop years ago?
oops wrong forum...
joe
Semper Fi
My 68 Torino
Old 04-19-2018, 10:33 PM
gofastwclass gofastwclass is offline
Hahaha!!!
Nice floor Lance! I love the new place.
I build my own junk...
Old 04-20-2018, 09:12 AM
rickpaw rickpaw is offline
Love the new place. Thanks for sharing Lance.
Tu Ho
Old 05-05-2018, 12:52 PM
SSLance's Avatar
I guess it's time for a bit on an update on the shop's progress. I'm starting to get things put away and a bit more organized, starting with my tools.
I knew I wanted a 72" rolling chest for storage and finally found this Trinity on sale for $675 on Wayfair so I snatched it up. Once it got here and I did the final assembly, I went back inside and tried to order a couple more...but alas they were back to regular price of $991. They are REALLY nice for the money. Not Snap-On or MAC tools nice but still dang stout.
It's already full and the top covered and I still have stuff in bins...so I'll need at least one more if not 2.
I'm liking the chests lined up down the center of the shop so far, still need to tweak things but so far the plan is working.
It's a bit easier to work out in the shop now that the AC has been installed. It is so nice when you find a contractor that does a job neat and tidy as I would do it myself and Cactus Mechanical here in Phoenix did just that with this install.
I took the 50 AMP RV plug the builder installed in the wall out and extended the 6\3 WG into this surface mount distribution panel and then ran another piece of 6\3 out to a disconnect directly outside for the condensor.
While I was at it I ran a 30 amp 230v plug right under the box for my welder and a 20 amp 230v circuit for the inside air handler. I then called Greg at Cactus Mechanical and told him I was ready. Couple of days later they installed this 5 ton Heat pump including the pre-built return base and extended feed out the top.
It was 92 degrees inside the shop at 4 in the afternoon when they fired it off and when I came back about an hour and a half later it was down to 80 and comfortable everywhere inside the shop. You can feel the breeze from the feed all the way at the front end of the shop and the walls, floors and even the ceiling are all within 1-2 degrees of each other everywhere. I think it's going to work out just fine.
Lance
Old 05-05-2018, 01:20 PM
It looks so good Lance!!
I'm sorry --- I did have to laugh just a bit though at the thought of the A/C pulling the shop down from 90 to 80...... WAIT!!! WAIT until it's 115* outside and has been for weeks.....
OMG the thought of moving to that kind takes my breath away. I will need a summer place!
