Old 02-07-2020, 06:35 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Maybe I missed it, but what coolant pumps are you using for the supercharger?
Instagram- camaroaj
Old 02-07-2020, 06:54 AM
cwylie cwylie is offline
It looks like the factory C7 ZR1 pumps.
Old 02-08-2020, 03:52 AM
Stielow's Avatar
Stielow Stielow is offline
Yep!
Stielow Engineering
Old 02-08-2020, 02:38 PM
randy randy is offline
What are the two inner tabs on the front of the subframe by the body bushing holes?
The engine bay is going back together today. I like this part of the project.
Packaging all the stuff in!
Old 02-08-2020, 05:21 PM
Stielow's Avatar
Lower radiator mounts.
Stielow Engineering
Old 02-12-2020, 10:59 AM
jmac jmac is offline
What are you using, and where are you mounting the reservoir for the clutch master cylinder?
Thanks!
Old 02-12-2020, 08:11 PM
MtotheIKEo MtotheIKEo is offline
Thanks!
Look back a few pages, very informative set of posts on the clutch pedal/master installation.
Old 02-13-2020, 04:22 AM
Yes those pics and step by step instructions were amazing in detail. My Dorman master cylinder and 4th gen clutch pedal are sitting on the bench and I'm about to duplicate the same thing.
I was curious about the reservoir that holds the fluid, is he using a white plastic OE looking one, or some trick billet one? Where's it mounted? On the firewall by the brake booster, or stealthy and hidden somewhere?
Thanks!
Old 02-13-2020, 04:44 AM
Stielow's Avatar
Thanks!
I like the OE look of the stock reservoir It will mounted on the fire wheel where it is already to bleed and any bubbles will have a path to get back to the reservoir.
Stielow Engineering
Old 02-16-2020, 04:59 PM
Jimbo1367 Jimbo1367 is offline
Mark,
I think for your next build you should try sometihng a little outside your comfort zone and do a 70-73 Camaro RS . What would be your thoughts on something like that?
