Old 07-17-2014, 05:47 PM
57hemicuda's Avatar
57hemicuda 57hemicuda is offline
I read thru this -- didn't really find any particular nugget of info to hang a hat on... such as 60/40 or whatever....
What I did find --- was a mindset.... which is --- Race cars with race tires are to be thought of differently than street cars with street tires. Important only because a lot of the things we hear and base info off of may be "street" info rather than "race" info. The math used alone is almost DOUBLE using the sticky race tire with a coefficient of 1.5 versus the street tire of .08 makes a huge difference in what the tires can handle and their stopping distances.
Weight bias - front to rear - and more importantly weight TRANSFER under braking... I know my Mustang doesn't nose dive like my street cars do... etc.
http://www.stoptech.com/technical-su...alance-matters
Funny Greg, that nugget your looking for is to truly not take anything for granted. Don't assume anything, just because parts are new, no guarantees that they will work properly. I still say the setup I was running should have been at least been in the ball park, the new master was just defective.
Instead of taking the extra day or two to check everything, my A.D.D. once again got the better of me. Too many projects not enough focus. Payton sent me his pressure gauges 2 years ago, but they didn't fit my calipers so I never checked.
I am definitely not an analysis to paralysis guy, I put things together and beat the sh*t out of it to find the week links. Now that I'm focused on the brakes, I'll screw with them until they work. There are so many variables with this crap, I feel the charts only get you in the ball park, the rest is all on you.
My car is the only one I've driven on a road course, so honestly I didn't know what "RIGHT" was. I can sure clue you in to what wrong is though.LOL
Old 07-17-2014, 09:02 PM
Originally Posted by Norm Peterson View Post
Well . . . sort of.
The point that I'm really trying to get across is that "nose dive" neither causes forward load transfer nor is it even a particularly good representation of how much forward LT is happening.
Only that "some is" (along with some general implications regarding values of the applicable geometric anti effects).
Norm
Here --- Let me explain it to you....
When I go hard into a corner at speed and I stomp on the brakes while turning in -- the weight transfers to the front - and the rear loses grip -- which makes the ass end of the car swap with the front end of the car.
I don't really care about the technical details or terminology.... I have a real good understanding of what to do, and what not to do, to get around the track. Ron Sutton explained it all to me -- "be nice to the tires". Good enough.
Old 07-18-2014, 05:27 AM
Norm Peterson's Avatar
Norm Peterson Norm Peterson is offline
Well, I hope this edit ↓↓↓ reads better for you. I really don't like having to use poor terminology to get the main point across, but I guess I have to make exceptions from time to time.
The point that I'm really trying to get across is that nose dive does not cause weight transfer. Nose dive isn't even very good at indicating how much weight transfer is happening. Only that some is.
Sorry, Ron.
Norm
Old 07-18-2014, 05:59 AM
Payton King's Avatar
Well I disagree with the last statement. It either transfers weight or force to the front tires or it it does not. We all know that it does. Works exactly the same way on the other end with acceleration. So you are stating no weight is transfered to the rear wheels when a drag car leaves the line with the front tires in the air?
Old 07-18-2014, 06:05 AM
bdahlg68's Avatar
bdahlg68 bdahlg68 is offline
No - what he is saying is a bit clearer now but the cause and effect is backwards.
He is saying nose dive doesn't cause weight transfer - which is correct because nose dive is an effect of weight transfer not a cause.
He is also saying that nose dive doesn't tell you how much weight is transferring which is also true due to the number of factors involved. Nose dive is simply an indication that weight is being transferred.
Brian
1968 Pontiac Firebird
1989 Ford Mustang
Old 07-18-2014, 06:28 AM
Greg <<<<<<< rattling around in his bag... AH! Here it is.... Beginning to transfer fluid....
Norm - Semantics and engineering gibberish aside. Anyone that has ever driven a car understands what "the point" is.
When the brakes are applied hard - especially during road racing or auto crossing etc - the front brakes need more braking power and the rear will need somewhat less - due to the coefficient of the tire / pavement / loading on the front vs the rear.
The amounts are all variable due to speed attained prior to the need to brake... and somehow the brain and the leg discuss this phenomena and come up with a plan. What the leg and the brain NEVER DO... is take the time to figure out if it's fluid transfer - nose dive - motion of the ocean - mass of the ass.... etc. The leg then carries out the "plan" and applies pressure on a flat pad attached to a lever - which then transfers that pressure to fluid - and that pressure is applied to more flat pads which press against rotating discs of steel.... and when the brain says -- I need more pressure - the leg applies more pressure and the previous technical analysis is multiplied -- or decreased if the brain said it wants less pressure - until the brain says - that's enough. Then the leg is told to switch positions and press on another flat pad attached to a different lever. This lever can now be electronic or mechanical but it's basic function is to transfer a different fluid - which, when mixed with the proper amount of air - and compressed - and lit - explodes in a controlled fashion and creates more pressure which pushes down on a different flat pad attached to a lever. Well... you get the point.
I think I have a better understanding of how this all works now. It's all about flat pads and levers and pressures and fluids of various viscosity. Funny when I think about it - this whole thing has another commonality. All these pads and fluids etc create heat. I'll have to do some reading about that.
Old 07-18-2014, 06:58 AM
Sieg's Avatar
Sieg Sieg is offline
Thankfully I drive by feel and learn from images more than theories and equations.
I've learned from images like this that sometimes rear brakes just aren't that important.
Old 07-18-2014, 07:47 AM
Vince@Meanstreets's Avatar
but theories and equations help you further understand and make improvments.
Reminds me of a story of a novice body man watching a 300 year old veteran work metal.
The novice " I see you are using the off dolly technique"
The veteran "What? I have no idea what you are ******* saying. I just hit the metal and it does what ever I ***** want it to do".
Now back to more pictures.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 07-18-2014, 10:51 AM
Thank you.
When cause and effect get mixed up, you can end up making wrong conclusions. Using the relative amount of nose dive between a race Mustang and somebody's DD (what started this tangent off) to suggest that the DD transfers more weight forward is a classic example.
Sieg - I also drive by feel, and I don't have to be on a track to be consciously aware that I am. On the track, I'm also driving with some awareness of the sounds of cornering. The engineer is on break during such times ands deals with things later.
Norm
Old 07-18-2014, 11:48 AM
It was never stated that a daily driver transfers more weight/force...just that a street car normally has more front dive. We all understand that the amount of front dive a car has under braking has to do with the spring rate, shock dampening, anti-dive built into the front suspesion, rate of deceleration, etc.
Back to our regularly scheduled thread "As the Car Stops" starring Good Ron as a middle aged car builder/boy racer with no rear brakes. When we last left off, Good Ron had discovered that his Mustang never had rear brakes due to a bad master...that is where the journey started as he replaced the faulty master with 2 new racy masters and a balance bar system. Tune in next week when you will hear Good Ron say, "My fricken car stops awesome! Why did I wait 2 years to fix this crap?"
My guess to the answer to that question is: It was easier to build an AMX than it was to take 10 minutes to diagnose the problem.
