Old 05-17-2010, 06:47 PM
boostin05blacks boostin05blacks is offline
Default 67 Camaro - Dad and Son build
Well Ill give a bit of history on the car and will try to update as we go, have problems, questions ect. The car was a plane jane 1967 camaro that has been in my family since 1969. My grandfather worked for GM his whole life and in 1967 when the camaro came out a manager at where my grandfather worked got a 1967 camaro in butternutt yellow with a 327, powerglide and not to many options. Well in 1969 when the body was revised that manager wanted to get a 1969 camaro. So his 1967 was then put up for auction and my grandfather having 6 kids all around the driving age put a bid in of $200 for the car. Well as the story has it he won the car. My dad tells me stories of when my grandfather brought the car home and he wanted the car. The car was then passes along the girls (my aunts) up untill 1991 where it was then parked. My dad always told himself that one day he would have the car. Around 2000 me and my dad went and picked the car up from my aunts house. We picked at the car little by little not really knowing where to start. Up untill now.
I have been doing alot of research and I think/hope these are going to be the final plans for the car. I will be getting pictures up the next time I am at the car. We plan on holding off on the body as it pretty much needs everything at this point and we have decided for this summer to try to tackle the mechanical stuff and make the car a great driver first. Please if you have some opinions/comments share. Input is always a good thing. The goal for the car is going to basically be a great cruiser with a couple of dragstrip trips in store and mabye road/auto course later down the road. We want to be able to run at least mid-low 11's with the car. Around 550-600 wheel. With that in mind..here is the current list..and the current wish list for the car.
Current:
LSX 454 GMPP crate motor
FAST lsxr 102 intake
FAST Fuel rails
Nick Williams 102mm Throttle body
C6 Front Accesory drive
Mast Motorsport Oil pan
S&P Motor adapters
Energy Suspension motor mounts
Energy Suspension Poly Kit
Speed tech solid aluminum body mounts
Custom subframe connectors
QA1 front coil-overs
Corbeau CR1 Front seats
Forgeline DS3- 18 x 8.5, 18 x 12
Wilwood 12.1 drilled/slotted -6 piston(front) 4 piston(rear)
Ricks Stainless Tank (efi)
Moser 12 bolt ( 35 spline, wavetrac, 3.73)
prodigy 4 link w/ QA1 coil-overs
DSE mini tub
6 point custom cage
Anvil Carbon fiber (cowl panel, header panel, front spoiler, hood, trunk)
Wish list:
T56 Magnum 6-speed kit
Anvil Carbon fiber (rear spoiler)
Stainless brake lines
225-245/40/18, 335/30/18 tires
Headers
Wiring Harness, ecu, sensors, ect..
Injectors
Stuff for sale:
Rs fenders(original)
Cowl panel (original)
Doors (original)
ls2 engine covers (shaved)
NOS gm 2" cowl hood
Old 05-19-2010, 04:02 PM
So the following has been order.:
Moser 12 bolt rear 3.73 gear 35 spline wavetrack diff.
Wilwood full brake set up. 6 piston up front and 4 piston in the rear 12.1 drilled/slotted rotors all around.
Ricks stainless steel tank set up for efi.
Big thanks to frank over at prodigy customs..next up is the t56 magnum and the lsx 454 soon after that...its going to be an awsome summer and I have been waiting and dreaming of doing this with me father for the last 10 years...
Heres an update from last week..we have takin apart almost the whole car and are waiting till next winter or summer to tackle the body. Its just to much money to put out at once...we basically need everything body wise so we decided to just get the car in perfect working order first and then worry about how it looks. With that being said the whole car is basically stripped and ready for some new parts. Here is where we are at now.
Ready for the pull, bye bye old 327 and powerglide...
Out and conquered...haha
Also heres my other car that ive had since highschool thanks to my dads help...its my daily also..
and having alittle fun
and another project I have going on..this will be my daily once its done..
and one of the car I finished (old dd) and sold for a ring for my fiancee
I guess you can say I like cars....the camaro was and always will be my first love though...
Old 05-19-2010, 04:14 PM
scherp69's Avatar
scherp69 scherp69 is offline
Welcome to the site. Sounds like a great project, can't wait to see some pics.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 05-19-2010, 04:15 PM
awr68's Avatar
awr68 awr68 is offline
Very cool project....I love to hear about these Father - Son projects! Best of luck with it and enjoy the journey!!
Tony
'68 Camaro
Old 05-19-2010, 05:24 PM
Great project working with your father. Keep the pictures coming
Old 05-19-2010, 07:46 PM
E.rodz's Avatar
E.rodz E.rodz is offline
welcome to the place were inovation never sleeps.looks like a cool project cherrish the years that you and your father can spend together.keep your dreams alive .
my name is Eric Hokenson I have a dream of building ten of the coolest hot rods out of my home shop wish me luck I am going to need it! - more pics on my web site www.erodzcustoms.com this is just for fun and i am NOT looking for any more work!
Thank you supporting sponsors! without you guys there is no way I could do this myself !
Modern automotive performance,Ring bros.,Yank convertors,extreme drive systems,Cj tunes,race coatings stainless works,Modern Automotive Performance.all of these shops have the experience to get your car to the top.
Old 05-19-2010, 09:07 PM
dlouie87's Avatar
dlouie87 dlouie87 is offline
From one STi owner to other!
G/L on build.
Old 06-24-2010, 08:22 PM
makindue84 makindue84 is offline
Current:
QA1 Street Star rear shocks
Hotchkins Multil-leaf drop springs
Cragar S/S 17 x 8(front) 17 x 10 (rear)
Wish list:
Weld draglite wheels w/ MT slicks (track duty)
Some type of track bars (newer style)
Need to decide/figure out many things still I know that. Im still doing alot of reading on the ls motors and Im pretty sure I still want to put a carburetor on the 454..any input on the set-up..? Clutch set-up recommended..? Thanks Steven
For your Energy Suspension Poly Kit, I think we have the same kit. I am planning to look for the new updates for this kit.
Old 06-26-2010, 03:34 PM
Ok so the box from ricks camaro never came and I wanted to do the front end today also. At least get the new ball joints pressed in the upper and lower arms..but no fedex. So I just worked on the rear. The por-15 came in yesterday so I went over to my dads and painted the rear with two coats. After that I put the rear brake assembly together and the alxes in. Also grabbed the rear wheels to see what there gonna look like. Here are the pictures..
Mabye tommorow I will get over there and start on the front frame..if not deff by tuesday...more updates coming soon..
Old 06-26-2010, 04:14 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Looks good man!
