Old 04-20-2017, 11:53 AM
DanielBurko DanielBurko is offline
Nice work going into that car. Wow. Very impressive!
Old 04-26-2017, 06:24 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
Thank you.
I went and picked the frame up from the blaster at lunch today and the two met each others for the first time.
Well 4 guys and about 30 min later with minor cutting the frame fits! Saturday I'll bolt the front fenders, front suspension, and rear suspension on to get the frame square in the body and lined up in the wheel wells. It's going to be low, frame is set at 5.5" of ground clearance!
Old 04-26-2017, 07:36 PM
Zoomin Zoomin is offline
OO
Snice!!!
1964 Lemans
1966 Skylark
1969 Camaro
Old 04-27-2017, 08:34 AM
CamaroAJ's Avatar
Originally Posted by Zoomin View Post
OO
Snice!!!
Thanks bud
Old 04-28-2017, 09:16 AM
The real work begins after the wedding . . .
Old 05-01-2017, 06:23 AM
CamaroAJ's Avatar
Lots of work got done Saturday on the car. First step was to get the suspension, and front fenders installed for measuring and then just that, lots and lots of measuring, adjusting, and clamping. After a few hours of getting things aligned I was able to weld to rockers to the frame. and see how the car looks as a whole piece again. Onward to pictures!
Needless to say there is going to be some cutting of the frame ends involved.
Stock 17x9 C5 Z06 wheel to check measurements. With a custom offset wheel I should be good on my clearances in the front.
And even with 5.5" of ground clearance I still have a good amount of height on the front to clear speed bumps
Frame welded to the rockers and supporting most of its self
I also got a start on the defuser layout.
Old 05-01-2017, 07:33 AM
Build-It-Break-it's Avatar
Awesome job. Your making it look easy.
Ahmad B
Old 05-01-2017, 07:56 AM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Looks great!
Old 05-01-2017, 09:10 AM
Amazing work AJ. I have trouble cutting a 2x4 to an exact measurement. I always look forward to your updates, keep them coming!
Old 05-01-2017, 11:34 AM
CamaroAJ's Avatar
Originally Posted by Josh@Ridetech View Post
Looks great!
Thanks guys, I appreciate it.
