Old 06-27-2007, 10:51 AM
kennyd's Avatar
kennyd kennyd is offline
we use areomotive a1000 pumps , they can be inside the tank or outside . the willys is using a a1000 outside with fast injection , and the camaro is also using a a1000 inside the tank from rick's tanks .
the willys is not loud at all .
i also have a weldon pump on the 33 with a 8 stack hilborn converted with fast , its loud for a pump i will probally change to a a1000
Old 10-25-2007, 07:24 PM
PHJ426 PHJ426 is offline
Default EDI pump in tank?
How hard is it to buy a new repop tank for a car (72 Road Runner in my case) and install an EFI pumpin the tank?
Anyone have a picture of a converted tank?
Here is one option:
http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm
Old 10-26-2007, 05:24 AM
GeoffP GeoffP is offline
I have had the Walbro 255 lph in my 87 IROC's tank for 4-5 years. No problems at all and only slightly more noisy than stock. I'd recommend it to anyone.
GeoffP
68 Camaro LT1/T56
87 Camaro IROC LT1/4L60E
Old 11-07-2007, 10:33 PM
Tom.A's Avatar
Tom.A Tom.A is offline
[QUOTE=kennyd]we use areomotive a1000 pumps , they can be inside the tank or outside . the willys is using a a1000 outside with fast injection , and the camaro is also using a a1000 inside the tank from rick's tanks .
the willys is not loud at all .[/COLOR][/COLOR]
Is the A1000 pump good? I am about to order a Rick's EFI tank and that seems to be the one that it comes with the Stealth version.
Thanks,
Tom
Old 11-07-2007, 11:33 PM
Originally Posted by clill
My understanding is Bosch makes a nice in tank pump with the screen built in.
Does anybody have part number ? Or pics ? And has anybody fitted one in a stock tank ?
Aeromotives are cool but personally would not trust one for loooong run.
63 Z06
Old 11-08-2007, 05:05 AM
How noisy is the Walbro ?
What pump? Is there a electric pump in there? So quite you have to put your ear on the tank to hear if it is running. I love them. We sell the heck out of those.
Frank Serafine
Old 11-08-2007, 05:35 AM
[QUOTE=tom_a]
Thanks,
We sell a ton of Rick's Stealth tanks with no complaints about the A1000, but there are plenty of stories about A1000s failing or boiling fuel returning to much fuel. Then there is a legendary Power Tour tale about a guy named MacGyver (or maybe the name is Jody?) that had a interesting cure for a over zealous A1000 a few years ago......................
A Walbro will be fine for 600HP,
Frank Serafine
Old 03-25-2008, 10:44 PM
Dark Angel's Avatar
Dark Angel Dark Angel is offline
Im running the Walbro 255 in my "01 LS1. 400 RWHP motor and I was spraying another 150 shot on top of that at one point and never had a problem with running out of fuel or running lean. Like everyone else said on noise, they are fine. I head alot of stock intank pumps that are louder.
'01 Onyx Z28 12.75 @ 113.24
'67 Camaro 327
'72 El Camino
'87 'Burb. 6.2 Turbo Diesel
Old 04-05-2008, 10:37 AM
James OLC's Avatar
The Bosch pump that Kinsler spec'ed for us (and we are using in our Rick's Stainless tank) is part number 10211. It's rated to 390 lbs/hr at 70 psi pressure.
Kinlser has a decent pump comparison in their tech manual here
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
