Old 10-17-2007, 05:46 PM
GT500KR_Vert's Avatar
GT500KR_Vert GT500KR_Vert is offline
Back Home In The Garage
Old 10-19-2007, 08:56 AM
Default Back home in the garage
I've got some good leads on moving the car to a new restoration shop to finish up the body & chassis work.
In the meantime I'll install the suspension and brakes to let it roll again.
Old 03-10-2009, 08:22 PM
Update:
I've been busy this last 1.5 years getting another degree, a stressful job and commute, wife/kids, work around the house; so I let the car sit. I kept talking to people about good guys to work with and I found someone a while back. I also had to find and buy little parts that were lost when I got my car back. That took a while because some of them were original mustang parts that are hard to find. Now I'm getting back to the project. I let it sit too long, a little surface rust developed. Going back over the car today I noticed a bunch of things the previous guy did wrong while working on it. I also had to remove all the little items he didn't bother to take off before he sprayed it with primer (besides the rust he sprayed right over) like the ignition & headlight switches, the covertible top switch, little screws on the interior, pieces of the dashboard, washer pump, a sheetmetal screw he used to hold a panel in place while he welded it, the door handles and locks. So it's finally stripped.
One of the biggest problems the last two days has been trying to figure out all the little nuts and bolts that were lost by the last builder and replacing them while installing the rear and front suspension and getting it rolling again. I had to bring it home on carpet dollies. I had a few trips to the local auto store to get that fixed.
Anyway I organized all my parts, boxed up the one needed for the next phase of the project.
Next Phase:
* Finish MII suspension
* Install the engine
* Create a custom trans mount
* Install subframe connectors
* Install 3" Magnaflow exhaust
* Modify Total Control's X-brace to fit with a custom vert support bracing.
* Finish the sheet metal for the engine compartment
* Order custom Ron Davis radiator - the original Ron Davis one i ordered did not fit.
* Mount Radiator
* Spray rust preventer on the Interior(Non-Visible), inside doors, engine compartment, underbody, and any other hidden spot I can shoot.
* Then paint the engine compartment black.
* Paint the underbody with bedliner coating
* Finalize rear suspension
* Install Dynamat
* Install Wiring
* Install Brakes / Plumbing
* Install Fuel system
At this point the engine should be in, exhaust in, wiring in, trans in, suspension in, brakes in, fuel system in, and the car drivable.
The next step will be to find a body shop to repair minor issues, prep and paint the car.
Finally back on all 4 wheels, load with all the parts to go to the new builder, and ready to roll!
I'm so excited to take another step towards it's completion. So are my little boys, they "Helped" today and yesterday with little things like tightening bolts and helping use the air impact. Plus it's been like 20 degrees outside.
1968 Shelby GT500KR Vert
CarDomain: http://www.cardomain.com/ride/2576876
Old 03-10-2009, 08:26 PM
Current Photos:
Picked up a Fuel Safe Pro Cell - 22 Gallon.
Old 03-10-2009, 08:38 PM
I was worried about backspacing, but they look like they fit fine as is. Plus I'm probably still going to mini-tub when the rear quarters are replaced. I'll probably have the tires on next week sometime, trying decide if I should go local or buy from the tire rack. Local is a little more money, but they mount and balance them; plus if I have to change sizes later they said they would do it. I've been getting our cars serviced at this place for years.
Old 03-10-2009, 08:43 PM
Default I think that catches you back up.
Ever Since I Saw It On The ReenMachine Mustang I Wanted To Use The Fox Body Style Bar On Mine. $225, Never Used On Craig's List, 5 Miles From My House. What Are The Odds? The Shelby One Goes For $800 + Shipping.
Cleaned Up The Rear Seat Frame
Old 03-11-2009, 01:35 AM
Looks like your off to a good start if you want any led lights for it http://www.mustangproject.com/ and procar does make a rear seat cover that matches there front but it says for a 67 not sure if the 68 back seat is the same.
Old 03-11-2009, 01:37 PM
Your car is looking good. The roll bar looks nice and I love the wheels.
Old 03-11-2009, 09:33 PM
GHOSTDANCER GHOSTDANCER is offline
Good looking Mustang
Old 03-12-2009, 04:26 AM
I have the led lights already and I was first in line for the rear seat cover, but it took over a year to get because the pattern from the first batch were wrong.
Thank for the info though.
