View Poll Results: Which LSX oil pan finish do you like the best?
Gray Powdercoating 3 7.32%
Clear Powdercoating 27 65.85%
Neither of them 11 26.83%
Voters: 41. You may not vote on this poll
Old 07-13-2007, 04:37 PM
Default LSX oil pan finishes- You decide.
Boys and Girls-
We have decided against zinc plating our oil pans because it is getting hard to find a decent company to do it in a reasonable time frame.
We have decided on two options- The first is a light gray powdercoating that looks very OEM like and matches the rest of the LSX factory parts.
The second option is one my fabricator thought of after he used scotch-brite on the entire pan. We then had it cleared with powder coating. I like this one because it shows the amazing TIG welds he is able to lay down. they look like a tiny stack of dimes laid out.
Pick your favorite finish and leave us feedback! You could end up deciding how we finish our products!
Tyler
Old 07-13-2007, 05:00 PM
buickfunnycar.com's Avatar
I voted neither.The grey does nothing for me...and it hides all the neat welds.
Clear is better...but still doesn't do much for me.
www.buickfunnycar.com
Old 07-13-2007, 05:26 PM
camcojb camcojb is offline
I'd prefer black. I know, not on your list.
Old 07-13-2007, 07:28 PM
4mm 4mm is offline
I used to like the grey and still do but not as much. Two of my engines use a grey that is almost identical. IMO, there should also be a satin black option or a nice bright metallic aluminum powdercoating.
In fact I am changing the grey on the engine to the metallic aluminum finish and the other black.
Old 07-14-2007, 12:55 AM
youthpastor's Avatar
clear looks killer, nice work guys
Old 07-14-2007, 10:36 AM
Derek69SS's Avatar
I like the raw look of the clear PDC, but not the discoloration from the welds.
I would go with a darker gray though if you're going to put color on it. Something close to the look of "cast iron gray" spray paint.
Old 07-16-2007, 02:19 PM
BThibodeaux BThibodeaux is offline
I voted neither. I do like the look of the clear. However, assuming the oil pan is made of steel, I don't think I would do this because it WILL get chips, and the chipped areas will become little rust spots. If I am off base, and the pan is aluminum, ignore this. If not, I would go with clear zinc plating. IMO this would look good with the aluminum block, and be much more resistant to rusting when the gravel flys.
Brian T.
2011 Chevrolet Camaro Convertible
