Old 09-23-2007, 06:47 PM
chicane's Avatar
chicane chicane is offline
...Good point with the vent tube lengths.
The metering plate vents and jet extentions will help with this a little as well.
Old 09-23-2007, 07:27 PM
4mm 4mm is offline
I had the same problem in my Mustang. When I would corner/turn hard, the engine would start sputtering and start to die and I would have to slow down and pedal on the gas a bit to keep the engine running and from dying. Same thing when braking hard.
The carb had been rebuilt in spec to my engine but they failed to install the fuel baffles that help keep the gas from spilling from the vent tube.
Old 09-24-2007, 02:28 AM
if you dont have a carb spacer get one they are cheap and help alot.
Old 09-24-2007, 10:20 AM
mazspeed's Avatar
mazspeed mazspeed is offline
Problem with that is the hood clearence. Ill go down there today and see if that's working as they do want to put one on.
Old 10-02-2007, 08:40 PM
so did you fix the problem or still scratching your head.
